Multiple Wav Files In Play Module
#1 Guest_Paul_* 01 February 2003 - 02:28 AM
wink.gif I would like to know how to get the play module to play more than one wav file, the help says seperate
the wav files with a comma but this does not appear to work. I have an approximate 5 minute message and need longer than the 60 seconds than the module supports, the closest I have come is the last wav file plays and disregards the first one.
Any help would be appreciated, I am running the evaluation version currently.
Paul
#2 SupportTeam 01 February 2003 - 02:32 PM
Are you perhaps using an old version of VoiceGuide which did not support multiple sound files?
If you are using a current version (4.8.45) could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
Here are the traces of the tests that I've just made - I set up a script with a Play module in which I specified to have 4 sound files played one after another. The filenames were separated by commas. I tested on both Modems and Dialogic cards, and both worked OK.
Dialogic:
28671 6 [TestMultiPlay] Playing
28671 6 [TestMultiPlay] Playing (C:\Projects\vg32\system\voicedlgc\0.WAV, C:\Projects\vg32\system\voicedlgc\1.WAV,C:\Projects\vg32\system\voicedlgc\2.WAV, C:\Projects\vg32\system\voicedlgc\3.WAV)
28671 6 PlayMulti(1)[C:\Projects\vg32\system\voicedlgc\0.WAV]
28671 6 PlayMulti(2)[C:\Projects\vg32\system\voicedlgc\1.WAV]
28671 6 PlayMulti(3)[C:\Projects\vg32\system\voicedlgc\2.WAV]
28671 6 PlayMulti(4)[C:\Projects\vg32\system\voicedlgc\3.WAV]
28703 6 PlaySoundStartMulti ok
28703 6 RunModule PLAY end
31968 6 Play End line[6] (id=928671)
31968 6 LsPlayMsg EV_PLAY_FINISHED
Modem:
62718 0 [TestMultiPlay] Playing
62718 0 [TestMultiPlay] Playing (C:\Projects\vg32\system\voice\0.WAV, C:\Projects\vg32\system\voice\1.WAV,C:\Projects\vg32\system\voice\2.WAV, C:\Projects\vg32\system\voice\3.WAV)
62734 0 PlayMulti(1)[C:\Projects\vg32\system\voice\0.WAV]
62734 0 PlayMulti(2)[C:\Projects\vg32\system\voice\1.WAV]
62734 0 PlayMulti(3)[C:\Projects\vg32\system\voice\2.WAV]
62734 0 PlayMulti(4)[C:\Projects\vg32\system\voice\3.WAV]
63109 0 PlaySoundStartMulti ok
63109 0 RunModule PLAY end
66312 0 Play End line[0] (id=162734)
66328 0 LsPlayMsg EV_PLAY_FINISHED
Regarding your second problem:
There is no limit on the length of the sound file you can use in the Play module (why are you under impression that it only supports 60 seconds?).
We have mentioned before that Modem's wave drivers take longr to sart playing long sound files, but this only applied to sound files which are 20+ monites long.
(Dialogic have no problems playing soundfiles longer then one hour...)
I've again captured some traces to show this. First I had a Dialogic card play a 30 minute sound file. Trace shows:
48203 6 [Play 11] Playing (Dlgc30min.wav)
48359 6 PlaySoundStart ok [C:\Projects\vg32\Scripts\Dlgc30min.wav]
you can see that it took 150ms for the Dialogic to load and start playing the 30 minute sound file. (those numbers on left hand side show milliseconds)
Next I had the modem play a 5 minute sound file:
22468 0 [TestPlayLongFile] Playing (Mdm5min.wav)
24218 0 PlaySoundStart ok [C:\Projects\vg32\Scripts\Mdm5min.wav]
It took the Modem's Wave drivers about 1.8 seconds to load the file and start playing it...
If you are finding that your system behaves differently please send us a copy of VoiceGuide's Debug Printout which captures the problem.
#3 SupportTeam 01 February 2003 - 04:22 PM
Also, the Evaluation version is no way limited in the lengths of the sound files that can be played... you can play 10 hour long sound files if you need to (use Dialogic cards)...
The Evaluation version of VoiceGuide functions just like the Enterprise version + the VoiceGuide Dialer add-on - (it's only limitation is that it needs to be restarted every hour)...
#4 Guest_Paul_* 02 February 2003 - 02:45 PM
Thank you for your reply,
I got the impression of the 60 seconds because when I opened the sound recorder
and started recording, it would count up to 60 seconds and stop, but I noticed if you stop
recording and restart, you continue with another 60 seconds from where you left off.
I just assumed it would be continuous, am I doing something wrong or is this how it works ?
I should mention I am using a modem and believe I am recording via the sound card, the modem wave
drivers appear to be loaded correctly, however I can not seem to record through it.
Paul.
#5 SupportTeam 02 February 2003 - 08:14 PM
The Window's Sound Recorder is a pretty basic tool, and it has the 60 second record limit.
We recommend using CoolEdit for recording and editing of sound files - an evaluation version can be obtained from:
http://www.cooledit.com/
The sound files you intend to use in your script should be recorded using the sound card, you should not use the modem to record your script's sound files...
If you can play files though the modem after the call is answered then there should be no problems with recording caller's messages - if there are some glitches encountered while recording could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
