cjdevconpro Report post Posted 03/17/2005 11:25 PM If there are any VB.NET examples, can someone please direct me to them? Thanks Share this post Link to post
SupportTeam Report post Posted 03/17/2005 11:33 PM Examples of what? What are you trying to do? Share this post Link to post
cjdevconpro Report post Posted 03/17/2005 11:47 PM Well first, I cannot get the VB6 apps to work. I have installed the newest version of VG today. I rebooted, then started VG and tried running the Popup Application and it states it cannot find the project or library for the VoiceGuide.CommandLink. So, once I get the sample apps running, I need to port them to VB.NET. Share this post Link to post
SupportTeam Report post Posted 03/18/2005 12:11 AM I think VoiceGuide must be started before VB6 will be able to see the VoiceGuide.CommandLink interface. Have you tried using the sample VBScript snippets from the Help file? Share this post Link to post
cjdevconpro Report post Posted 03/18/2005 12:18 AM I ran the "get finance.yahoo.com.vbs" script while VG was running. And it popped a MsgBox with results. I then closed down VG and ran the VBS script again and it popped the same results. More info: When I try to run the VB6 app "Answer and Record", it still gives me the missing library error. When it prompts me the Reference, it shows Missing: VoiceGuide Any ideas? Share this post Link to post
SupportTeam Report post Posted 03/18/2005 01:30 AM When I try to run the VB6 app "Answer and Record", it still gives me the missing library error. Is VoiceGuide running at the time? VoiceGuide acts as an "ActiveX Server". VG needs to be running when you try to access it's COM interface functions. Share this post Link to post
cjdevconpro Report post Posted 03/18/2005 01:54 AM Yes. It is running. when I open up the Task Mgr, I see VgGsd.exe and VgMulti.exe running. Share this post Link to post
SupportTeam Report post Posted 03/18/2005 03:00 AM Do vb script: set vg = CreateObject("VoiceGuide.CommandLink") vg.Admin_TraceLogAdd 0, 0, "This trace was printed from an external VB Script" set vg = Nothing and see if the message appears in VoiceGuide's Trace Log window. Don't know why you are having errors when accessing VG's COM interface when VG is running - when it is running it's COM interface is active. Note that in Evaluation version of the software you will only be able to test once COM call at a time and you will have to restart VG afterwards in order for another COM call to work - but the ActiveX server will be running and it will accept the COM command - it will just not act on it (there will be a message in the Trace Log advising you of this) Share this post Link to post
cjdevconpro Report post Posted 03/18/2005 03:18 AM I have the Enterprise 1 line version. The trace commands seem to work. do you have a VB.NET sample call to see if it is working? Share this post Link to post
SupportTeam Report post Posted 03/18/2005 04:38 AM The VB.NET is the same as the VBScript example... This works from VB.NET (you can use the VBScript pretty much unchanged). You will have the add a reference to VoiceGuide.CommandLink to the VB.NET project as well. : Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load Dim vg As VoiceGuide.CommandLink vg = CreateObject("VoiceGuide.CommandLink") vg.Admin_TraceLogAdd(0, 0, "This trace was printed from an external VB.NET Program") vg = Nothing End Sub Share this post Link to post
