When using the DbConnectString_ADO setting in VG for Dialogic with SQL Server, will the MsgQue be treated similarly to the CallQue or does the setting apply to CallQue only?
Page 1 of 1
Using Dbconnectstring_ado With Vg For Dialogic Using with MsgQue
#2
Posted 20 May 2005 - 11:02 AM
What MsgQue table are you referring to? CallQue is the only table within the "VoiceGuide" database in MSSQL Server.
See: http://voiceguide.co...t=ST&f=2&t=2696
#3
Posted 21 May 2005 - 03:34 AM
From the example that was provided, i was able to create the callque table in SQL Server which works wonderfully. In the voice guide data folder, i see another mdb file named EmailQue containing a table called MsgQue which appears to be responsible for holding data for the email module. If I were to create the same MsgQue table in SQL Server, would it work the same way for emails as the CallQue table does for outdailing?
#4
Posted 21 May 2005 - 08:44 AM
No.
Any email sending done by VG is so low-volume that moving it out to use MSSQL Server for temporary storage does not really give any benefits.
#5 Guest_Guest_*
Posted 24 May 2005 - 04:58 AM
That's too bad. It could be useful to utilize the SQL Server insert/update/delete trigger functionality.
Regardless, VG is a phenominal product!
Page 1 of 1
Sign In
Register
Help
