Vb Script Not Running
#1 David Flaks 28 September 2005 - 07:31 AM
I am having a problem with a vb script:[C:\Telecaller\Rendon\DB_Human.vgs]
172522.55 0 Script Load C:\Telecaller\Rendon\DB_Human.vgs
172522.55 6 Loaded VbsAtHangup into:2
172522.56 6 tapi Reply (LineEvReply) ok 66476 0
172522.56 6 timer clear
172522.58 6 [Update Database] Running VB Script...
172522.58 6 rv replace start (strlen>500)
172522.58 6 rv ns [RecordID]{REN333777}[PatName]{David}[ApptDate]{0610}[ApptTime]{C:\Telecaller\WAVtime\0830.wav}[Provider]{C:\TeleCaller\Rendon\WAV\Nurse.wav}[PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[OutDial_RetriesLeft]{2}[OutDial_Result]{Contacted_Human}[ScriptEnd_Time]{
/27/2005 5:24:46 PM}[ScriptEnd_Goto_Script]{C:\Telecaller\Rendon\HumanExistPat.vgs}[ScriptEnd_Goto_Module]{}[ScriptStart_Time]{9/27/2005 5:24:46 PM}[ScriptsPath]{C:\Telecaller\Rendon\}[Options]{1}[Hangup Time]{9/27/2005 5:25:22 PM}
172522.59 6 eng run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_6_1.vbs" //I] copy of script in: vbs_6_1.vbs
172522.63 6 Run Script waiting. iRunWait=1 (shellid=2496, process=1992)
172522.64 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172523.66 6 timer fired EV_TIMEOUT_CHECKONSTATE
172523.66 6 ScriptEventCode 9007 iLineState=1501
172523.66 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172523.67 6 task still running (shellid=2496, process=1992)
172523.67 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172524.77 6 timer fired EV_TIMEOUT_CHECKONSTATE
172524.78 6 ScriptEventCode 9007 iLineState=1501
172524.78 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172524.78 6 task still running (shellid=2496, process=1992)
172524.80 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172525.89 6 timer fired EV_TIMEOUT_CHECKONSTATE
172525.89 6 ScriptEventCode 9007 iLineState=1501
172525.89 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172525.91 6 task still running (shellid=2496, process=1992)
172525.91 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172527.00 6 timer fired EV_TIMEOUT_CHECKONSTATE
172527.00 6 ScriptEventCode 9007 iLineState=1501
172527.00 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172527.02 6 task still running (shellid=2496, process=1992)
172527.02 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172528.11 6 timer fired EV_TIMEOUT_CHECKONSTATE
172528.11 6 ScriptEventCode 9007 iLineState=1501
172528.11 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172528.13 6 task still running (shellid=2496, process=1992)
172528.13 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172529.22 6 timer fired EV_TIMEOUT_CHECKONSTATE
172529.22 6 ScriptEventCode 9007 iLineState=1501
172529.22 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172529.23 6 task still running (shellid=2496, process=1992)
172529.23 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172530.33 6 timer fired EV_TIMEOUT_CHECKONSTATE
172530.33 6 ScriptEventCode 9007 iLineState=1501
172530.33 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172530.34 6 task still running (shellid=2496, process=1992)
172530.34 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172531.44 6 timer fired EV_TIMEOUT_CHECKONSTATE
172531.44 6 ScriptEventCode 9007 iLineState=1501
172531.44 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172531.45 6 task still running (shellid=2496, process=1992)
172531.45 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172532.55 6 timer fired EV_TIMEOUT_CHECKONSTATE
172532.55 6 ScriptEventCode 9007 iLineState=1501
172532.55 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172532.56 6 task still running (shellid=2496, process=1992)
172532.56 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172533.66 6 timer fired EV_TIMEOUT_CHECKONSTATE
172533.66 6 ScriptEventCode 9007 iLineState=1501
172533.66 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172533.67 6 task still running (shellid=2496, process=1992)
172533.67 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172534.77 6 timer fired EV_TIMEOUT_CHECKONSTATE
172534.77 6 ScriptEventCode 9007 iLineState=1501
172534.77 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172534.78 6 task still running (shellid=2496, process=1992)
172534.78 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172535.88 6 timer fired EV_TIMEOUT_CHECKONSTATE
172535.88 6 ScriptEventCode 9007 iLineState=1501
172535.88 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
172535.89 6 task still running (shellid=2496, process=1992)
172535.89 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
172536.34 0 btn Hangup on line 6
172536.34 6 ScriptEventCode 9001 iLineState=1501
172536.34 6 LsRunWaitTillFinished EV_TIMEOUT_HANGUP
172536.36 6 rv add [Hangup Time]{9/27/2005 5:25:36 PM}
172536.36 6 Hanging up call...
172536.36 6 HangupCall_Common Mode=AfterHangupRun
172536.38 6 ReinitTelephony due to IDLE
172536.38 6 tapic lineDeallocateCall(MainCall:66493) 0
172536.47 6 lineOpen(6)=>
172536.48 6 Waiting for a call...
172536.48 6 LineHandle=65571
172536.50 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
172537.06 0 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|
172539.67 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
172539.67 6 ScriptEventCode 9013 iLineState=900
172540.08 0 dial start any summary:|6:idx=0|7:idx=0|8:idx=0|
#2 SupportTeam 28 September 2005 - 09:55 AM
Looking at the VBScript you have a while loop there and that's where probably the script gets stuck and never returns - and VoiceGuide can bee seen waiting for the script to return.
I'd suggest adding some tracing to your script to see why the VBScript gets stuck in a loop. See: http://www.voiceguid...TraceLogAdd.htm
#3 David Flaks 28 September 2005 - 10:58 AM
I think that it is important for you to know that I have been using this exact same script on another computer for a few months. I have just bought another computer and have installed version 5.2.3063 on the new computer with a new dialogic card D/4PCIU. The old computer was running on version 5.2.2001 with an ISA dialogic card. Could there be any difference caused by this.
#4 David Flaks 28 September 2005 - 11:19 AM
I have just tried to run the script without the loop as follows
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
on error resume next
set tsFile = fso.OpenTextFile("C:\Telecaller\LOG\LogHuman.txt", ForAppending, True)
tsFile.WriteLine "$RV[RecordId], $RV_STARTTIME, $RV[Options], $RV_CALLLENGTH, $RV[OutDial_RetriesLeft], $RV[OutDial_Result], $RV[NewPatientOptions], $RV[GetFaxNo]"
tsFile.Close
set tsFile = Nothing
set fso = Nothing
Exactly the same happened. Any suggestions?
#5 SupportTeam 28 September 2005 - 01:32 PM
If the VBScript completes without any errors then VoiceGuide should detect that and not wait anymore...
Can you post the VoiceGuide script which you are using and we can run a few tests on our demo system here.
#6 David Flaks 28 September 2005 - 09:27 PM
Here is the vb script
