Stops while playing a sound file
I got a simple IVR script. The 1st wave for language selection plays well. However, the 2nd wave plays for 1 or 2 sec then the call hangs up. The 2nd wave file is 24sec in length. Here is the trace log:
47546 0 tapie callstate OFFERING 0 4
47562 0 tapie ring 1
47562 0 Start without answering the call
47562 0 TimeoutClear
47562 0 [Get Language] Playing
47562 0 lineAnswer(65590) => 65641
47578 0 tapie callstate ACCEPTED 0 0
52656 0 tapi Reply 65641 0
52656 0 tapie callstate CONNECTED 65590,0,0
52656 0 WorkingModeTAPI=
52656 0 WorkingModeScript=BeforeAnswerRun
52656 0 TimeoutClear
52656 0 [Get Language] Playing
52656 0 [Get Language] Playing (z:\sprcivr\wave\select-lang.wav)
52890 0 PlaySoundStart ok [z:\sprcivr\wave\select-lang.wav]
52890 0 TimeoutClear
52890 0 RunModule PLAY end
52890 0 wa(7562,55267100)
60906 0 Play End line[0] (id=552671)
60906 0 LsPlayMsg EV_PLAY_FINISHED
60906 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
60921 0 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
61234 0 tapie monitordigits 49 2
61234 0 LsPlayMsgFinished [1]
61250 0 TimeoutClear
61250 0 [Menu] Playing
61250 0 [Menu] Playing (z:\sprcivr\wave\menu-main-c.wav)
62453 0 PlaySoundStart ok [z:\sprcivr\wave\menu-main-c.wav]
62453 0 TimeoutClear
62453 0 RunModule PLAY end
62453 0 wa(21693,56126500)
67828 0 tapie callstate DISCONNECTED 65590,32,0
67828 0 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
68171 0 PlaySoundStop ok
68171 0 Hanging up call...
68171 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
68187 0 fnHangupCall end
68203 0 tapi Reply 66393 LINEERR_INVALCALLSTATE [8000001C]
69843 0 tapie callstate IDLE 0 0
69843 0 WorkingMode@Idle=
69843 0 TimeoutClear
69937 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
69937 0 tapi Reply 65897 0
70937 0 Timer fired 0, 9008
70937 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
70937 0 Initialise telephony (due to IDLE)
70937 0 tapic lineDeallocateCall(MainCall:65590) 0
72562 0 Waiting for a call...
72562 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
78031 0 Timer fired 0, 9025
Thank you.
It looks like your modem thinks that it has heard a busy tone on the telephone line while playing the file - this sometimes happens with some voice modems who's busy tone detection has not been well tuned - when they play sound files they sometimes end up thinking that they are also hearing busy tones on the line.
Solutions:
A: re-record the sound file
or
B: try using a different modem...
Once the modem thinks it has heard the busy tone it will inform the TAPI driver that this call has disconnected, and TAPI driver will in turn inform VoiceGuide - and the call must then be finished..
