Voiceguide Automaticly Hangups Incoming Call
VoiceGuide AUTOMATICLY hangups incoming call after 1-2 second ????
WHY ??
Trace log events:
161503,30 6 devstate NUMCALLS 0 0
161503,30 6 tapi callstate start
161503,30 6 tapi callstate OFFERING 65675 0 4
161503,31 6 callinfo CALLEDID
161503,31 6 callinfo ORIGIN
161503,31 6 ring 0
161504,13 0 dial start any summary:|6:hc>0|
161509,31 6 ring 2
161509,31 6 rv clear
161509,31 6 Answer the call at 2005-11-22 16:15:09
161509,31 6 lineAnswer(65675) => 65624
161509,86 6 tapi callstate start
161509,86 6 tapi callstate CONNECTED 65675 1 0
161509,86 6 callstate CONNECTED 65675,1,0
161509,86 6 WorkingModeTAPI@Connected=
161509,86 6 WorkingModeScript@Connected=
161509,86 6 Inband detection not enabled
161509,88 6 StartLoadedVgs at 2005-11-22 16:15:09, script interpretor VgMulti v5.2.5012 0
161509,88 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
161509,88 6 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts}
161509,88 6 rv lg add [$RV_STARTTIME]{2005-11-22 16:15:09}
161509,88 6 rv lg add [$RV_DEVICEID]{6}
161509,88 6 rv lg add [$RV_CIDNAME]{}
161509,89 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
161509,89 6 rv lg add [$RV_CIDNUMBER]{}
161509,89 6 rv lg add [$RV_DNIS]{}
161509,89 6 rv lg add [DNIS]{}
161509,89 6 tapi Reply (LineEvReply) ok 65624 0
161509,89 6 callinfo MONITORMODES
161509,91 6 timer clear
161509,91 6 state [Play 1] Playing
161509,91 6 state [Play 1] Playing (C:\Documents and Settings\LRW\Pulpit\CISZA.wav)
161509,91 6 play set playid=327671
161509,92 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Documents and Settings\LRW\Pulpit\CISZA.wav]
161509,92 6 path {WAVERR_BADFORMAT} not found
161509,92 6 play set playid=327671
161509,95 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
161509,98 6 For Dialogic use: PCM 11Khz 8bit Mono
161509,98 6 rv lg add [Hangup Time]{2005-11-22 16:15:09}
161509,98 6 state Hanging up call... [srlib PlaySoundStart]
161510,00 6 RecSoundStop ok
161510,00 6 PlaySoundStop err=0
161510,00 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
161510,00 6 fnHangupCall end
161510,00 6 RunModule PLAY end
161510,02 6 play end current play (playid=0)
161510,02 6 ScriptEventCode 8001 iLineState=900
161510,02 6 LsAwaitingCalls EV_PLAY_FINISHED
161510,03 6 LsAwaitingCalls EV_PLAY_FINISHED
161511,89 6 devstate NUMCALLS 0 0
161511,89 6 tapi callstate start
161511,91 6 tapi callstate IDLE 65675 0 0
161511,91 6 WorkingMode@Idle=
161511,91 6 timer clear
161511,92 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
161511,92 6 tapi Reply (LineEvReply) ok 65982 0
161512,98 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
161512,98 6 ScriptEventCode 9008 iLineState=900
161512,98 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
161512,98 6 ReinitTelephony due to IDLE
161512,98 6 tapic lineDeallocateCall(MainCall:65675) 0
161513,08 6 lineOpen(6)=>
161513,09 6 state Waiting for a call...
161513,09 6 LineHandle=65931
161513,09 6 amchk set AMdet=False in Reinit@idle
161513,09 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
161513,13 0 dial start any summary:|6:rdy=0|
161516,38 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
161516,38 6 ScriptEventCode 9013 iLineState=900
161517,13 0 dial start any summary:|6:idx=0|
Help me
zorbasoft
In trace you can see:
It looks like your sound files are not recorded in the correct format.
See: http://www.voiceguide.com/vghelp/html/SoundFiles.htm
Also, for Dialogic based systems you're best to just start using "VG for Dialogic"...
