System specs:
P4 3GHz, 1GB RAM, SATA HD
WinXP SP2
SR6.0 SU84
DMV1200B card.
VoiceGuide for Dialogic v6.0.2430
The DMV1200B card has 4 E1 ports. These ports were looped back to each other so calls going out on first E1 line would arrive on the 3rd, and calls made on 2nd E1 line would arrive on the 4th.
VoiceGuide was started and about 10,000 calls were loaded using the telephone numeber loader. Outgoing calls were set to run script "cc test 1.vgs" upon connection. Channels accepting calls were setup to run the "Credit Card Payment" demo script.
The "Credit card Payment" demo script was designed to log relevant info at the end of the call into the file output.txt.
The outgoing "cc test 1.vgs" script was a series of modules which would generate the DTMF tones or play sound files
The scripts used, the output, basic tracing and the CPU usage during the test are available in the attachment provided.
Basically it shows that when running intensive scripts on all 120 lines the CPU usage was reasonable (30% average) and that the memory and handles usage did not grow during the calls made.
The output.txt file also shows that no DTMF tones were 'missed' by the system.
The DTMF tones sent over the system have been generated at a much faster rate then what a human caller would press (see sound files used), resulting in the lines being tested at a much more active level then what they would experience on average.
Logging was reduced to a minimum level (1).
Attached File(s)
LoadTestResults.zip (708.06K)
Sign In
Register
Help
