Evaluate Expression Not Working
I need an urgent help. My Voiceguide IVR application is not working and i have a demo presentation soon. Please kindly check my attached ZIP Voiceguide IVR application to see how you can help.
MY Problem
1). Evaluate Expression not working. I tried to check how many times a user has retried the process of entering User ID and limit it to only 1 time but That wouldnt work. Please check my script and see how u can help.
2). I am using Evaluate Expression to compare a users entered number against the information retrive from Access DB. example Evaluate Expression :
"$RV[GetUserRecord_2_1]"="$RV[AskUserPIN]"
But this is also not working. What i'm trying to achive is to compare the User entered PIN against The PIN code retrive from the datadase.
on {False} goto [userPINDontMatch]
on {True} goto [PlayDetails]
Please kindly check attached Zip containing VG Code and others for the possible errors why my code not working.
regards
Presentation.zip
You can enable the automatic saving of the logs to files in \log\ directory as well.
