Problem Playing Wav In Dialogic...
i am moving a operative voiceguide working properly to a new scenario and i am having a problem in new system (w2k server): i have a D120JCT Dialogic card, i have installed drivers and SP1, i have installed Dialogic Wave Drivers (following your help file) and the format of my wav file is PCM 11025Hz, 8bit, Mono, but i am getting error in time to play (even for your ErrorPlayingFile.wav). This is the log:
140804,42 4 Answer the call at 23/03/2006 14:08:04
140804,42 4 lineAnswer(66014) => 65980
140804,97 4 [Play 1] Playing
140804,97 4 [Play 1] Playing (C:\plusnet\soft\VoxAlert\Locuciones\Bienvenido.wav)
140804,98 4 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen failed MMSYSERR_BADDEVICEID] [C:\plusnet\soft\VoxAlert\Locuciones\Bienvenido.wav]
140805,00 4 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen failed MMSYSERR_BADDEVICEID] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
140805,00 4 For Dialogic use: PCM 11Khz 8bit Mono
140805,00 4 Hanging up call... [srlib PlaySoundStart]
140805,00 4 RecSoundStop ok
140805,00 4 PlaySoundStop err=0
140805,02 4 fnHangupCall end
140805,02 4 RunModule PLAY end
140806,98 4 WorkingMode@Idle=
140808,03 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
140808,03 4 ReinitTelephony due to IDLE
140808,09 4 Waiting for a call...
140808,09 4 LineHandle=65912
141230,44 0 Unloading Main Window
can you please help me?
thanks in advance,
Alberto
Use VoiceGuide for Dialogic.
Do not even install Dialogic's TAPI/Wave drivers.
Uninstall everything and then follow instructions in the VoiceGuide for Dialogic's readme.txt file.
hi,
i have upgraded to Vg for dialogic and i can play wav properly, but i have a new problem. After hang up, call continues in line. I have seen error messages in log file (attached).
thanks,
Alberto
0323vgm.txt
