VoiceGuide: Call Progress Tones - VoiceGuide
Page 1 of 1
  • Login to start a new topic
  • You cannot reply to this topic
Call Progress Tones Questions about ConfigLine.xml
#1 User is offline   jackthehack Icon
  • Group: Members
Posted 02 March 2007 - 12:41 AM
Attached File  0301tw.txt (22.58K)
Number of downloads: 33Attached File  0301vgm.txt (5.36K)
D/4PCI
Windows XP
I get the impression that my call progress tone definitions are being ignored, in favor of dialogic defaults. Is this the case? The Call Progress results are often wrong, for example showing CR_BUSY when this is definitely not the case.
I have massaged my call definitions using all of the recommended methods.
The attached log files reflect the default ConfigLine file in use. When I remove the ConfigLine file altogether, I get similar results as when it is there.
Thanks,
Jack
#2 User is offline   SupportTeam Icon
  • Group: Admin
Posted 02 March 2007 - 06:34 AM
The tones used are the ones specified in ConfigLine.xml file.
Attached traces show the following tones were read in:
QUOTE
090527.656 tone an id:FAX:191, f1:1100:110, cad:30:15:0:0, count:0
090527.687 tone an id:DISCONNECT_TAPI1 192 f1:620:200, f2:480:200, cad:30:10:20:10, count:3
090527.718 tone an id:DISCONNECT_TAPI2:193, f1:550:200, cad:30:10:20:10, count:3
090527.750 tone an id:DISCONNECT_Telstra:194, f1:425:50, cad:37:5:37:5, count:2
090527.781 tone ch id:TID_DIAL_LCL:250, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
090527.781 tone ch id:TID_DIAL_INTL:251, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
090527.781 tone ch id:TID_DIAL_XTRA:252, f1:340:40, f2:440:40, cad:100:0,0:0, count:1
090527.781 tone ch id:TID_BUSY1:253, f1:500:200, f2:0:0, cad:55:40,55:40, count:4
090527.781 tone ch id:TID_RNGBK1:254, f1:438:138, f2:0:0, cad:130:105,400:200, count:1
090527.781 tone ch id:TID_BUSY2:255, f1:500:200, f2:525:175, cad:55:40,55:40, count:4
090527.781 tone ch id:TID_DISCONNECT:257, f1:500:200, f2:525:175, cad:55:40,55:40, count:4
090527.781 tone ch id:TID_FAX1:258, f1:2150:50, f2:0:0, cad:25:25,0:0, count:1
090527.781 tone ch id:TID_FAX2:259, f1:1100:50, f2:0:0, cad:25:25,0:0, count:1
Both the TID_BUSY1 and TID_BUSY2 tone definitions do not appear to have been modified and remain set to default values.
You should change the tone definitions to reflect the Busy/Ringback/Disconnect tones played by the Telco/PBX.
Traces so not show any calls so we cannot see what tones were detected during the call.
#3 User is offline   jackthehack Icon
  • Group: Members
Posted 02 March 2007 - 09:59 AM
Attached File  0301vgm.txt (4.27K)
Number of downloads: 32Attached File  0301tw.txt (15.8K)
The attached logs reflect an outbound call successfully executed using my modified ConfigFile.
I see the tone definitions being read from the ConfigFile, but during the call progress analysis, I don't see any reference to tones defined in ConfigFile, such as 'TID_RNGBK1'. If I delete the ConfigFile altogether, and make the same call, while the ConfigFile is reported as not being found, the call progress analysis looks the same.
I get the impression that the call progress analysis is being done based on dialogic default tone definitions and not those provided in the ConfigFile.
What am I missing?
Thanks,
Jack
#4 User is offline   SupportTeam Icon
  • Group: Admin
Posted 02 March 2007 - 03:39 PM
Tones are being set as per ConfigLine.xml.
In "tw" trace you can even see:
184452.140 setting call progress tones according to [F:\Program Files\VoiceGuide\data\ConfigLine.xml]
and we can see that the call was successfull as 16 seconds after the number was dialed the Dialogic card detected that call was answered by a live person:
184508.968 001 TDX_CALLP CR_CNCT CON_PVD (connection due to Positive Voice Detection)
Why do you say you are having problems?
You have not posted any traces showing any problems...
#5 User is offline   jackthehack Icon
  • Group: Members
Posted 02 March 2007 - 08:32 PM
Attached File  0302vgm.txt (4.22K)
Number of downloads: 22Attached File  0302tw.txt (12.26K)
I understand that the call is being answered properly. I am merely asking for yor kind consideration in helping me to understand.
The attached traces reflect a similar call as in my previous post, except in this case I have DELETED my ConfigFile:
051739.390 init config line file not found [F:\Program Files\VoiceGuide\data\ConfigLine.xml]
Nevertheless, as was pointed out previously, the call is being proiperly answered:
051820.437 001 TDX_CALLP CR_CNCT CON_PVD (connection due to Positive Voice Detection)
My question is, in this case, from where is VG getting its tone definitions from?
Thank you for your patience,
Jack
#6 User is offline   SupportTeam Icon
  • Group: Admin
Posted 03 March 2007 - 08:45 AM
If ConfigLine.xml is not supplied then Dialogic uses it's own default settings.
Page 1 of 1
