Can't Create Object "msxml2.domdocument"
Dave Heyliger wrote:
I get the error
Can't Create object "Msxml2.DOMDocument"
when going into the Voicemail system (v5.0 of VG)
Looks like MSXML extensions have not installed themselves - can you please
either:
- try re-installing VoiceGuide again - this time selecting "No" to any
"Restart Windows Now" prompts - the MSXML is installed last and and looks
like sometimes another component installed just prior to it sometimes asks
for a Windows restart...
0r
- download MSXML from:
http://msdn.microsoft.com/downloads/list/x.../xmlgeneral.asp
and install it.
I'm having the same error. I have tried both fixes (downloading & installing MsXML as well as re-installing VG). Neither worked...
Not too sure what would cause MSXML not to install itself properly...
Which OS/Service Pack/ version if IE has this system got installed?
What I'd try doing next is installing any major Service Packs and ensuring that IE6 is installed on your system - then try installing MSXML again.
BTW. we got a note from Dave Heyliger advising that downloading and installing MSXML fixed the issue on his system.
The O/S is Windows 2000 Pro with SP4. (A fresh install just for VG.)
IE is 5.0. This is the 1st mention of any requirement for IE 6. Microsoft's MsXML download page doesn't mention this, nor do the MsXML Release Notes.
It seems to me that the install script should check this before allowing an installation atop IE 5.
I will try IE 6 next.
