Tts In Enterprise Version
#1 nmvarnitski 10 February 2003 - 10:27 PM
in professional version of IVG it says that: 'Text to Speech (TTS) is unavailable".
In order for me to play information retreived from the database I need to have TTS and will need enterprise license for my computer.
Is that correct?
#2 SupportTeam 11 February 2003 - 11:05 AM
Some basic information - such as numbers, amounts and time/date can be played by the Say Numbers module. This module does not require TTS as it plays back the information by concatenating pre-recorded sound files (which can be found VoiceGuide's \system\voice\ directory).
If the information you want to play back requires you to speak information other then that (eg: description of the product) then you will require TTS - which is only available in the Enterprise version.
TTS is the only difference between the Professional version and the Enterprise version.
