I Am Not Sure What To Do!
HEY everyone,
Voice guide along with a diagilogic card have worked great using the script examples but I have no idea how to make a script that ask about 16 questions that take numeric responses and creates a text file from the answers. Maybe this is simple to alot of people but I am asking for help.
Tscott
Have a look at attached script. It asks 4 questions then saves callers responses to file c:\output.txt
Have a look at the paths in each module and at the VBScript module.
Let us know if you have any further questions.
Questionaire.vgs
I looked at the script that u provided and tried to make some modifications. Everytime I make a modification the phone will pick up and nothingelse will happen. here is the script I am trying to use. this is a test.
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Save
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[save]
Type=Run VB Script
DispSize=69
Txt=
VbsFileToRun=
VbsWait=1
VbScript=
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set tsFile = fso.OpenTextFile("C:\Documents and Settings\bookstudy\My Documents\BIOMARKER", ForAppending, True)
tsFile.WriteLine "$RV_STARTTIME, $RV_CIDNUMBER, $RV_CIDNAME, $RV[CID], $RV[iVR1], $RV[iVR2], $RV[iVR3],$RV[iVR4], $RV[iVR5], $RV[iVR6], $RV[iVR7],$RV[iVR8], $RV[iVR9]"
tsFile.Close
set tsFile = Nothing
set fso = Nothing
VbsHoldPlay=
Position=496,700
[iVR1]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR1Boyd.wav
Replay=2,5
strTtsText=
on {*9} goto [PLAY ACTION - Resume]
on {*1} goto [PLAY ACTION - Pause]
on {*} goto [iVR1]
on {#} goto [iVR2]
Position=179,71
[iVR3]
Type=Play
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR3Boyd.wav
Replay=2,5
strTtsText=
on {#} goto [iVR4]
on {*} goto [iVR3]
Position=64,282
[CID]
Type=Get Numbers
DispSize=69
Txt=Play a prompt asking the caller to enter a sequence of numbers, speak the sequence back to the caller and ask them to confirm it. Go down different paths depending on the numbers entered...
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\CIDBoyd.wav
PlayFile2=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Female Voice\voice MuLaw\GetNbrsConfirmIntro.wav
PlayFile3=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Female Voice\voice MuLaw\GetNbrsConfirmMenu.wav
Replay=2,7
GetNbrLen_Min=4
GetNbrLen_Max=4
Confirm=ON
VbScript=
VbsHoldPlay=
on {#} goto [iVR1]
on {*} goto [CID]
Position=21,7
[iVR2]
Type=Get Numbers
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR2Boyd.wav
Replay=2,5
GetNbrLen_Min=1
GetNbrLen_Max=1
Confirm=ON
VbScript=
VbsHoldPlay=
on {*} goto [iVR2]
on {#} goto [iVR3]
Position=337,150
[iVR5]
Type=Play
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR5Boyd.wav
Replay=2,5
strTtsText=
on {*} goto [iVR5]
on {#} goto [iVR6]
Position=151,399
[iVR4]
Type=Get Numbers
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR4Boyd.wav
Replay=2,5
GetNbrLen_Min=0
GetNbrLen_Max=2
Confirm=ON
VbScript=
VbsHoldPlay=
on {*} goto [iVR4]
on {#} goto [iVR5]
on {0} goto [iVR6]
Position=303,282
[iVR6]
Type=Play
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR6Boyd.wav
Replay=2,5
strTtsText=
on {*} goto [iVR6]
on {#} goto [iVR7]
on {0} goto [iVR8]
Position=416,407
[iVR7]
Type=Play
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR7Boyd.wav
Replay=2,5
strTtsText=
on {*} goto [iVR7]
on {#} goto [iVR8]
Position=159,546
[iVR8]
Type=Play
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR8Boyd.wav
Replay=2,5
strTtsText=
on {#} goto [iVR9]
on {0} goto [save]
on {0} goto [Conclusion]
Position=441,550
[Conclusion]
Type=Play
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Female Voice\voice MuLaw\Credit Card Payment\PayThankyou.wav
Replay=2,5
strTtsText=
Position=690,697
[iVR9]
Type=Play
DispSize=69
PlayFile1=C:\Documents and Settings\bookstudy\My Documents\BIOMARKER\Boyd\IVR9Boyd.wav
Replay=2,5
strTtsText=
on {#} goto [Conclusion]
on {#} goto [save]
on {*} goto [iVR9]
Position=809,481
You have set the module titled "Save" to be your starting module. As this is the module which saves the data to file I don’t think that’s right.
Set the start module in "Edit"->"Script Properties" menu.
I have been trying with no success too get a script that just takes a call and gets a few responses and saves it into a text file. Can some please look @ this script and help me complete this. I am enclosing the written phone script and the digital script.
Please change anything here to make this work. Or tell me what I need to change and I will do it.
Thanks in advance
myscriptdata.zip
In your VBScript module try starting off with something simple, like this:
set tsFile = fso.OpenTextFile("C:\out.txt", ForAppending, True)
tsFile.WriteLine "Hello"
tsFile.Close
set fso = Nothing
If that works then move onto something a little bit more complicated, like this:
tsFile.WriteLine "Hello $RV_STARTTIME, $RV_CIDNUMBER, $RV_CIDNAME, $RV[CID], $RV[iVR1]"
tsFile.Close
set fso = Nothing
and if that works then you can add more $RVs and try changing the file location as well.
If you still have problems please post the trace capturing the call itself and describe in detail what the problem is (eg: can't see any created file, or no data in file etc).
