Hi, I have a number of small but head-scratching questions. Can anyone help me?
Q1) In Ms-Access design view, how can I set up a table field so that the auto-number records come out in this format: 000 001 002 >>>999. I need zeros, so that when someone punches in an order number, there will be some response to a number beginning with zero. Also my set of autonumbers must begin with 0, not 1.
Q2) Using Access database XP: How can I use an update query to calculate and change something with in a record?
Q3) What simple program or combination of programs would I require to replicate records from a single table to some other database connected to the internet in another location? (I think this is called transactional replication) All I have been able to come up with so far, is a really expensive, and complicated solution involving MS SQL server enterprise, and a Win2000 Server operating system.
Any help on these questions would save me a lot of time searching for the answer. These questions (especially the last one) seem to be holding me back greatly!
Congratulations Katalina! VoiceGuide is a great program!
Page 1 of 1
Access Dbase Help newbie questions
#2
Posted 20 September 2003 - 04:43 PM
QUOTE
Not too sure how you can do it in Access - but you could after retrieving the number use a bit of VB Script code to pad the number out with leading zeros and then return the result back to VoiceGuide - you should use the Format function for this : Format(5,"0000") will return "0005" QUOTE
Best to ask in Access related newsgroups or have a read through the namuals for this one...QUOTE
To do this right you will probably need to move to SQL Server or similar - again best to ask on newsgroups for this, try:http://www.google.co...up_search?hl=en
Page 1 of 1
Sign In
Register
Help
