Guest ArgleBargle Report post Posted 09/25/2003 02:42 PM With VG 4.9.0 I could return a multi-rowed Result Variable as $RV[ModuleTitle_ColumnIndex_$RV[RowIndex]] in a VBScript file. That doesn't seem to be working any longer. Below is a code snippet which is accessing a multi rowed Result Variable. The code, which ran properly under 4.9.0, began failing when I loaded 5.0a. The variable "Counter" in this case has a value of one (1) as shown in the code snippet below. Also included below are the contents of the file "Translate App Type.txt" which shows the actual values returned. const ForWriting=2 iCtr=$RV[Counter] filename="Translate App Type.txt" set fso=CreateObject("Scripting.FileSystemObject") set ts=fso.OpenTextFile(filename,ForWriting,True) ts.Write "Counter Value=" ts.Write("$RV[Counter]") ts.Write vbcrlf ts.Write "Translated with a Results Variable=" ts.Write("$RV[GetAppTypeRecords_1_$RV[Counter]]") ts.Write vbcrlf ts.Write "Translated without a Results Variable=" ts.Write("$RV[GetAppTypeRecords_1_1]") ts.close File "Translate App Type.txt" contents... Counter Value=1 Translated with a Results Variable=] Translated without a Results Variable=Promotion As can be seen above, the result of $RV[Counter] is 1. When used with "$RV[GetAppTypeRecords_1_$RV[Counter]]" a right bracket is returned "]". When used with a hardcoded "1" in "$RV[GetAppTypeRecords_1_1]" the actual valued of the Result Variable "Promotion" is returned. Can you advise me of a way to use a variable to cycle through the values instead of having to hard code the RowIndex value? Share this post Link to post
SupportTeam Report post Posted 09/26/2003 02:49 AM We've just checked this and can confirm that this is a problem with v5.0a This issue will be resolved in soon to be released V5.1 Beta3. Share this post Link to post
