Graphical Output To Caller
Is it possible that a vbScript can display the prompts to the user on their pc screen as well as through audio files?
Yes. Plz see VBScript's MsgBox function. This will display a dialog box on the computer on which the VBScript is ran.
To send a message to another computer use WshShell.Run method to issue command:
net send [computername] [message text]
To determine to which computer to send the message to you will need to determine who is calling first - if Caller ID is not supplied then you will first need caller to enter an ID number first - then you will be able to determine which computer to send the message to...
Plz see VBScript docs for more info.
Another info page on MsgBox function is here:
http://www.netzone.ch/caspdoc/html/vbscrip...ox_function.htm
