Alcatel Oxe
Hello, I want to record a call from an agent.
I am attaching the logs and. vgs, etc, etc..
The pbx = alcatel oxe
the call arrives at VG, vg conference at the extension 8948,
the agent answers but not heard anything.
and not heard either client-side
Your help please
Br
Diego Mino
0423_1745_vgAgent.zip
Please update your system to these versions:
[old links removed]
please post traces capturing system startup and the incoming call if you still encounter problems.
ALREADY UPGRADED VERSION.THERE IS NO CHANGE.ERROR CONTINUESTHE PDF NO RELATIONSHIP WITH THE UPDATE 7.3.3 VGYOUR HELP PLEASE
br
DIEGO
log.zip
The ktTel trace shows:
414 111433.921 1252 ERROR TelDriver_TsRoute ag_getxmitslot 1 dxxxB1C2 : Invalid Switching Handler Bus Mode
What model Dialogic card are you using on this system?
To do "Dial and Conference"/"Tromboned" type transfers (which ACD system also uses) you need to use a "JCT" or "DMV" type card.
if you are not using a "JCT" or "DMV" type card the the two parties would not hear each other as the voice path connection would not be made.
From http://www.voiceguide.com/vghelp/source/html/modxfer.htm:
Dial and Conference General Notes:
The D4PCIU* family cards do not support "Dial and Conference". You need a JCT or DMV series card (eg. D/41JCT, D/120JCT, DMV160 etc.), or any T1/E1 Digital cards (eg. D/240JCT, DMV600B etc.)
This is now probably irrelevant as wrong card type is used:
In the original script the transfer is made using VoiceGuide's ACD system, with the transfer module using:
ACD:prueba
In the last script the transfer is made directly to an extension number 8948 instead, with call recording then being started from following VBScript.
Would you like to do the call transfers using the ACD system, with calls being received by logged in agents, or by just by transferring the call to a PBX extension directly?
ACD is not supported by Dialogic cards, d4pciu1?
Always transfer to the ACD will be a conference?
I can transfer with ACD, without conference?
Br
Diego
ACD uses the 'Dial and Conference' (Tromboned/2-Line) transfer to connect calls to agents.
D4PCI* series cards do not support 'Dial and Conference' transfers so it is not possible to use ACD on these cards.
Hello.
I put dialogic dmv600betep
ports are 8910 ... 8939
8948,8949,8950 extensions.
I call to port 8910 and I hope transferred to extension 8950.
this does not happen.
attached the logs, configuration and flow
regards
Diego
0513_1031_vgEngine.zip
Traces show the outgoing call was fine, and was answered 20 seconds after being dialed:
431 103837.937  2316   6 ev    GCEV_DETECTED crn=6000006
436 103837.937  2316   6 ev    GCEV_OFFERED crn=6000006 (ktTel_SR60 v7.3.3, Apr 22 2013 11:41:49)
445 103837.937  2316   6       ani:  orig:  name:  dnis:  dest:
448 103837.937  2316   6 r     CallState GCEV_OFFERED
450 103837.984   660   6 fn    AnswerCall(sXMLOptions=[])
456 103838.125  2316   6 ev    GCEV_ANSWERED crn=6000006 (ktTel_SR60 v7.3.3, Apr 22 2013 11:41:49)
468 103838.125  2316   6 r     Dialogic  GCEV_ANSWERED 2050 (2050 0 0   )
470 103838.125  2316   6 r     CallState GCEV_ANSWERED
474 103838.140  2316   6 ev    GCEV_LISTEN (2133 0x855) no handler.
476 103838.656   660   9 fn    LineMakeCall(iLineId=9, iCallRequestId=0 (ignored), strNumberToCall=[8950], callprog=CONNECT_IMMEDIATELY, timeout=60, params:0,6,cidtosend=[],opt=[<calltype>DialAndConf</calltype><CallerId></CallerId>])
500 103838.671   660     fn    TsRoute(sDev1Name=dtiB1T1, sDev1Type=, sDev2Name=dtiB1T2, sDev2Type=, sConnectionType=SC_FULLDUP
507 103838.734  2316   6 ev    GCEV_LISTEN (2133 0x855) no handler.
511 103838.796  2316   9 ev    GCEV_DIALING crn=6000009 crn_lastMakeCall=6000009
513 103838.796  2316   9 r     CallState GCEV_DIALING
518 103858.796  2316   9 ev    GCEV_CONNECTED (ktTel_SR60 v7.3.3, Apr 22 2013 11:41:49)
524 103858.796  2316   9 r     CallState GCEV_CONNECTED
103906.046 19   6   1 wcf   IPortStatus Action_Hangup call. iPort=1
What sort of systm is providing the E1 trunk? Is it still Alcatel Oxe ?
The Dailogic card shows that no DNIS or CallerID was sent with the call that arrived on system.
If you did not see the PBX sending a call to 8950 the you should do an ISDN level trace that will show the ISDN mesages exchanged between the Dialogic card and PBX.
