Record Conversation
Good Day!
Jus t want to ask how to record the conversation of the two line?
because after i transfer the call, and when the record start?the line also drop.
Can you kindly help me.
Thanks and Regards
Traces show that the call transfer made is a "Blind Hookflash Transfer".
2-line recording only works when a "Tromboned" ('Dial and Conference') call is set up first.
Theres 3 ttypes of"Dial and Conference(Blind,MOnitored and Anounce)"?which of this need to use?and also
the dial and conference not working?can you help me in this kind of problem?
Any one is fine. 'Blind' is the simplest one so recommend to use this one first.
and also the dial and conference not working?
'Dial and Conference' (Tromboned) transfers only work with JCT and DMV type cards.
What model Dialogic card are you using on your system?
how can i know which model Dialogic Card,
here i try to go to device manager then i see thos dialogic model.
Dialogic D41JCT-LS, D41JSF or D4pCI-U card
If this is correct?
Card model is usually shown on a sticker next to the port sockets.
If you can take a photograph of the card and post it here then we can see from photograph what is the model.
If it is an analog card and is a 'half-lenght' card then it is not a JCT or a DMV type card.
'Half-lenght' analog cards are all D/4PCI* series cards, which do not support CT-Bus, and hence do not support call bridging.
I already saw the white sticker you metion in the middle of the 4 ports.
D4PCIUFW is the card number. if the dialogic not support the call bridging,theres any way to
record the conversation between two lines?
This card does not support call bridging. There is no way to establish a bridge between two lines and as a result there is no way to be able to record a conversation between two bridged lines.
may i know which model do i need to use to record the conversation through phone and send fax also
