SupportTeam Report post Posted 03/04/2003 02:16 AM Bhagirath wrote: I am using VoiceGuide, Version 4.8.45 and I am still having problems. Please help. I have tried to read and re-read the online help. If you know the solution then please give an example. Thanks in advance (bhtgui@yahoo.com in US) I am on Windows XP, trying to use MySQL and have downloaded and installed MyODBC My database is---> C:\mysql\data\ivrbtv1_db In the ODBC Data Source Administrator dialog I have set the following in the User Data Sources table Name Driver --------------------------------- ivrbtv1_db MySQL Selecting Configure... on the above selected entry I get a dialog titled "TDX mysql Driver default configuration" and the settings in its are as follows: Windows DSN name: ivrbtv1_db MySQL host (name of IP): localhost MySQL database name: C:\mysql\data\ivrbtv1_db User: bhtgui Password: ***** Port (if not 3306): SQL command on connect: In the Interactive Voice Guide script I have set the following in the Query dtabase dialog: Database or ODBC Data Source: ivrbtv1_db Connect String: ( I have tried several combinations but none worked) MYODBC MYODBC;user=bhtgui;password=real password MYODBC;database=C:\mysql\data\ivrbtv1_db;user=bhtgui;password=real password Thanks Share this post Link to post
SupportTeam Report post Posted 03/04/2003 02:17 AM Best to consult the online manual for MySQL ODBC. It can be found at: http://www.mysql.com/products/myodbc/manual_toc.html One of the connect strings used in demonstrations in that manual: DRIVER={MySQL ODBC 3.51 Driver};SERVER=localhost;DATABASE=test;UID=venu;PWD=venu;OPTION=35 but I suggest consulting the manual to find the correct connection string for your system. Note: The name of the DRIVER used must match the name of the drivers that is being used on your system - this can usually be found in your "ODBC Data Source Administrator" Related post: http://katalinatech.com/forums/index.php?a...act=ST&f=2&t=16 Share this post Link to post
SupportTeam Report post Posted 03/06/2003 02:00 AM Bhagirath wrote: After putting all the hints together I finally managed to put the connecting string together. The solution is: (for using MySQL, MyODBC Version 02.50.38) ODBC;DRIVER={MySQL};server=localhost;database=dbName;user=userName;password=user assword;port=3306; Share this post Link to post
