Guest dbov21 Report post Posted 05/04/2013 08:24 AM I'm using the Run module to call shntool.exe to join several recorded wav files, works good. I can see though in the VG log file that my command is getting clipped off at the end if it's too long, causing it to fail. This commandline does work outside of VG. Can you tell me the max character length for a commandline using the Run Module? Also any chance of getting this to accept longer commandlines.. Thanks. Share this post Link to post
SupportTeam Report post Posted 05/04/2013 09:16 AM Probably fastest way to determine max command length in v6 is by trial and error. Can you perhaps post the traces capturing the Run Program call? The actual command executed may be shown in the traces. Share this post Link to post
SupportTeam Report post Posted 05/04/2013 09:20 AM v6 is no longer in development, so it would not be possible to make any changes to the v6 software. Share this post Link to post
