vkei Report post Posted 05/14/2013 09:18 AM (edited) i would like to know how a fax can be send via a D/480JCT-2T1 card i put a phone message module in call flow to make the dialout then put a .tiff to fax , it can dial to the number but can't connect and send the fax , 3 fax machine are tested , same result also try the call loader , same , is there any setting missed ? ---------- here are some log maybe useful [removed] Edited 05/14/2013 09:51 AM by SupportTeam removed quoted log Share this post Link to post
SupportTeam Report post Posted 05/14/2013 09:28 AM Can you please .ZIP up the entire ktTel trace file and .ZIP up the entire vgEngine trace file and post them as attachements. Please do not post large amounts of traces directly into post text itself. Share this post Link to post
vkei Report post Posted 05/14/2013 09:38 AM thanks for reply sure, zip file vg log 0514.zip Share this post Link to post
SupportTeam Report post Posted 05/14/2013 10:20 AM ktTel trace shows that all the dxxx devices that are specified to be opened do not support fax. From ktTel trace: 633 123000.241 1892 3 fx_open (dxxxB1C1) => -1, fax not supported on the primary voice device 662 123000.269 1892 5 fx_open (dxxxB1C2) => -1, fax not supported on the primary voice device 692 123000.299 1892 8 fx_open (dxxxB1C3) => -1, fax not supported on the primary voice device 721 123000.329 1892 11 fx_open (dxxxB1C4) => -1, fax not supported on the primary voice device 750 123000.356 1892 14 fx_open (dxxxB2C1) => -1, fax not supported on the primary voice device 779 123000.384 1892 17 fx_open (dxxxB2C2) => -1, fax not supported on the primary voice device 808 123000.414 1892 20 fx_open (dxxxB2C3) => -1, fax not supported on the primary voice device 837 123000.446 1892 23 fx_open (dxxxB2C4) => -1, fax not supported on the primary voice device 866 123000.477 1892 26 fx_open (dxxxB3C1) => -1, fax not supported on the primary voice device 895 123000.507 1892 29 fx_open (dxxxB3C2) => -1, fax not supported on the primary voice device 925 123000.537 1892 32 fx_open (dxxxB3C3) => -1, fax not supported on the primary voice device 954 123000.568 1892 35 fx_open (dxxxB3C4) => -1, fax not supported on the primary voice device 983 123000.598 1892 38 fx_open (dxxxB4C1) => -1, fax not supported on the primary voice device 012 123000.628 1892 41 fx_open (dxxxB4C2) => -1, fax not supported on the primary voice device 041 123000.658 1892 44 fx_open (dxxxB4C3) => -1, fax not supported on the primary voice device 070 123000.688 1892 47 fx_open (dxxxB4C4) => -1, fax not supported on the primary voice device 099 123000.718 1892 50 fx_open (dxxxB5C1) => -1, fax not supported on the primary voice device 128 123000.748 1892 53 fx_open (dxxxB5C2) => -1, fax not supported on the primary voice device 157 123000.778 1892 56 fx_open (dxxxB5C3) => -1, fax not supported on the primary voice device 187 123000.808 1892 59 fx_open (dxxxB5C4) => -1, fax not supported on the primary voice device 216 123000.839 1892 62 fx_open (dxxxB6C1) => -1, fax not supported on the primary voice device 245 123000.880 1892 65 fx_open (dxxxB6C2) => -1, fax not supported on the primary voice device and this is why system cannot send fax. ktTel trace shows: 879 123007.670 2540 3 ev GCEV_ALERTING crn=2800018 (ktTel_SR60vista v7.3.2, Nov 7 2012 23:53:41) 883 123007.672 2540 3 ev GCEV_PROGRESSING crn=2800018 886 123011.643 2540 3 ev GCEV_CONNECTED (ktTel_SR60vista v7.3.2, Nov 7 2012 23:53:41) 897 123011.665 1892 3 fn Fax_Tx_Start(sFileList=C:\Users\Administrator\Desktop\TestFax.tif, sHdr2=, sOptions=) 898 123011.665 1892 3 Fax_Tx_Start(strSoundFile=[C:\Users\Administrator\Desktop\TestFax.tif], sHdr1_LocalId=[], sHdr1_User=[VoiceGuide], sHdr2=[], sOptions=[]) 899 123011.665 1892 fax device not opened on this line. Aborting fax send. What is the full part number of this card? Is it a PCI or PCI-Express? You may want to contact the card supplier and ask them how to set the cards configuration so that it supports fax. Right now when querying the first channel of each 'Board' device on the card, the card responds that each of the tested channels does NOT support fax: from ktTel trace: 631 123000.213 1892 dxxxB1C1 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 661 123000.260 1892 dxxxB1C2 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 691 123000.291 1892 dxxxB1C3 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 720 123000.320 1892 dxxxB1C4 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 749 123000.348 1892 dxxxB2C1 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 778 123000.376 1892 dxxxB2C2 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 807 123000.406 1892 dxxxB2C3 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 836 123000.436 1892 dxxxB2C4 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 865 123000.467 1892 dxxxB3C1 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 894 123000.498 1892 dxxxB3C2 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 923 123000.527 1892 dxxxB3C3 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 953 123000.559 1892 dxxxB3C4 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 982 123000.588 1892 dxxxB4C1 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 011 123000.619 1892 dxxxB4C2 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 040 123000.650 1892 dxxxB4C3 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 069 123000.679 1892 dxxxB4C4 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 098 123000.708 1892 dxxxB5C1 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 127 123000.739 1892 dxxxB5C2 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 156 123000.768 1892 dxxxB5C3 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 186 123000.799 1892 dxxxB5C4 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 215 123000.828 1892 dxxxB6C1 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 244 123000.872 1892 dxxxB6C2 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 273 123000.900 1892 dxxxB6C3 : ft_e2p_brd_cfg: FT_CALLP FT_MF_TONE_DETECT FT_DPDft_play: FT_ADPCM FT_PCM FT_ALAW FT_ULAW FT_LINEAR FT_ITU_G_726 FT_ADSI FT_RAW64KBIT FT_DRT6KHZ FT_DRT8KHZ FT_DRT11KHZ FT_FSK_OH FT_MSGSM FT_RESRVD1ft_tone: FT_GTDENABLED FT_GTGENABLED FT_CADENCE_TONE : ft_play=0xd7ff, ft_record=0xdfff, ft_tone=0x7, ft_e2p_brd_cfg=0x26, ft_fax=0x0 There may be a setting required that will enable fax functionality. The card provider should be able to advise what that setting is for the card they provided. Most likely only some of the channels will support fax - so you may need to ensure that any outgoing fax calls are only made on those channels (this is easily set when loading calls in VoiceGuide) Share this post Link to post
SupportTeam Report post Posted 05/14/2013 10:52 AM If your card provider advises that the card that was supplied does not support fax when running ISDN, then a quick workaround may be to add a D/41JCT card to the system (linking both cards with CT-Bus cable) and specify that 4 of the dti channels on the D/480JCT use the 4 dxxx resources on the D/41JCT. (each of the dxxx resources on the D/41JCT supports fax and voice) Share this post Link to post
SupportTeam Report post Posted 05/14/2013 11:08 AM Since this is a 'Dual Span' card then it may be possible to set the dxxx devices on the second span to have fax enabled. In Dialogic Configuration Manager, on tab Misc, set FirmwareFile2 to be: spfax.fwl This will prevent you from using the second span for an ISDN trunk, but will give you access to some fax resources (most lilkely either 4 or 8) without adding any more cards. To find out which resource have the fax enabled after the change it is best to look at the "ft_fax=" report in ktTel trace after Dialogic service (and VoiceGuide service) restart after the firmware change is made. Share this post Link to post
vkei Report post Posted 05/14/2013 11:17 AM Thanks it is PCI i found a label showing the model is D/480JCT1T1W my DCM detected it as D/480JCT-2T1 #0 in slot 5/2 the card has only 1 T1 port , i think the 2T1 is just name of a series ? not really sure the only setting i make at the DCM is Interface > ISDNProtocol set to NI2 and ISDNProtocol2 set to None i find this information "Dialogic JCT series Media Boards configured to use the spfax.fwl firmware will have from 2 to 8 fax resource channels enabled." should i set the FirmwareFile or FirmwareFile2 to spfax.fwl in DCM ? it is now set to "default" Share this post Link to post
SupportTeam Report post Posted 05/14/2013 01:07 PM should i set the FirmwareFile or FirmwareFile2 to spfax.fwl in DCM ? FirmwareFile2 FirmwareFile should be left as 'default' Share this post Link to post
SupportTeam Report post Posted 05/15/2013 01:37 AM We have set up a D600JCT-1E1 (DCM does report it as D/600JCT-2E1) that we have in our testing lab to use ISDN on its E1 trunk, and set FirmwareFile2 to spfax.fwl (FirmwareFile was left as 'default'). ktTel trace showed that, on that card, 16 of the dxxx resources on the second span now were fax enabled (dxxxB9C1 to dxxxB12C4) You can edit the Config.xml to set which dxxx resources are to be used by VoiceGuide when opening the channel. In ktTel trace, when fax is enabled on a dxxx resource on a JCT card, you will see these tags on the line that reports dxxx features present (ft_e2p_brd_cfg report line) FT_FAX_EXT_TBL ft_fax=0x30 Share this post Link to post
vkei Report post Posted 05/15/2013 07:23 AM after the FirmwareFile2 set , it reported B9C1 to B12C4 has ft_fax=0x30 (no FT_FAX_EXT_TBL found) i changed the 23th channel from B6C3 to B9C1 in conf file <Device_Voice>dxxxB9C1</Device_Voice> <Device_Network>dtiB1T23</Device_Network> <Protocol>ISDN</Protocol> <RingsBeforeAnswer>0</RingsBeforeAnswer> <Script>C:\sp.vgs</Script> <CallerId></CallerId> <AllowDialOut>1</AllowDialOut> <--the only channel allowed i can now fax with the call loader... but i am getting a new error when try to use Phone Message module to create fax on demand 619 114508.565 1092 68 fn Fax_Tx_Start(sFileList=, sHdr2=, sOptions=) 620 114508.565 1092 68 Fax_Tx_Start(strSoundFile=[], sHdr1_LocalId=[], sHdr1_User=[VoiceGuide], sHdr2=[], sOptions=[]) 621 114508.565 1092 68 fax Fax_Tx_Start_Now begin 622 114508.565 1092 68 fax Clean_iottFax_chain 623 114508.565 1092 fax no files queued to send. 624 114508.565 1092 68 r Dialogic TFX_FAXSEND_ERROR 0 (0 0 0 ERROR no files queued to send ) in the .vgs file uploaded , "fax2" can send fax while "fax" can't ,my guess is, it dunno what to do when fax tone is detected ? 13.vgs Share this post Link to post
SupportTeam Report post Posted 05/15/2013 08:28 AM Could you please .ZIP up and post the vgEngine trace that captures the call. Alos please .ZIP up and post the ktTel trace. Share this post Link to post
vkei Report post Posted 05/15/2013 08:51 AM i tested many times , here should include the calls , thanks Archive.zip Share this post Link to post
SupportTeam Report post Posted 05/15/2013 09:20 AM Looks like there was a bug in sending faxes from "Send Message" module - which we are now fixing. As a workaround for now please see attached scripts. 13.vgs now specifies that a script is started upon call answer (JustSendFax.vgs), and sets a $RV that specifies the filename to fax. JustSendFax.vgs when ran sends the fax that is specified in the $RV Please let us know if you have any questions. Please also see: http://www.voiceguide.com/vghelp/source/html/diallistinto.htm section: "Out Dial Input file - VoiceGuide v7". Using that XML file gives you better control over outgoing call. including: sOnAnswerFax Fax to send. This can be a .PDF or a .TIFF file. Note that when this field is specified VoiceGuide will start playing the Fax Calling Tone immediately after the number is dialed. The OnAnswerLive and OnAnswerMachine will be ignored as only a fax send will be attempted during the call. 13.vgs JustSendFax.vgs Share this post Link to post
