Cannot Hangup line immediately
I am testing the download evaluation with a Motorola VoiceSurfer 56K External modem.
All the sample scripts runs fine. However after the hangup module finish and VoiceGuide return to waiting for another call, the line still occupied and release the line only after 30 seconds.
Is this a modem issue or telco issue?
Harman
If the modem does hangup the line (which it sounds like it does) then the inability to accept new calls on the line for next 30 seconds would be a telco issue...
What happens when you just plug a normal telephone handset on that line - are subsequent calls still blocked for 30 seconds after end of previous call?
The trace will show us if the modem drivers are reporting that the modem has hung up the line...
Hello,
This is the trace log for the Internet Portal script. I tried to connect a phone to the line after the hangup and cannot make any dial until 30 seconds later - there is no dial tone and just like the line is still in use.
Harman
135821.46 0 sys cleanup Start
135821.48 0 sys cleanup End
135829.05 1 callstate OFFERING 66426 0 4
135829.06 1 ring 1
135829.77 1 Lev_CallerID [90165251,]
135833.22 1 ring 2
135837.38 1 ring 3
135837.39 1 Answer the call at 1/13/2004 1:58:37 PM
135837.39 1 lineAnswer(66426) => 66443
135837.40 1 callstate ACCEPTED 66426 0 0
135839.55 1 tapi Reply (LineEvReply) ok 66443 0
135839.56 1 callstate CONNECTED 66426,0,0
135839.56 1 WorkingModeTAPI@Connected=
135839.57 1 WorkingModeScript@Connected=
135839.58 1 Inband detection not enabled
135839.58 1 StartLoadedVgs at 1/13/2004 1:58:39 PM
135839.58 1 [Welcome] Playing
135839.59 1 [Welcome] Playing (IpWelcome2.wav)
135839.90 1 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpWelcome2.wav]
135839.90 1 RunModule PLAY end
135842.55 1 Play End line[1] (id=155402)
135842.55 1 LsPlayMsg EV_PLAY_FINISHED
135842.55 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
135842.57 1 [GetMarketLevels] Running VB Script...
135842.57 1 RVreplace start (strlen>100)
135842.64 1 Run Script waiting... (shellid=1592, process=568)
135842.64 1 [GetMarketLevels] Playing (IpOnHold.wav)
135842.99 1 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpOnHold.wav]
135844.03 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
135844.03 1 task still running (shellid=1592, process=568)
135845.04 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
135845.04 1 task still running (shellid=1592, process=568)
135846.06 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
135846.06 1 task still running (shellid=1592, process=568)
135847.09 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
135847.10 1 task still running (shellid=1592, process=568)
135847.63 1 cl Run_ResultReturn >>[MarketDow]{10,485}[MarketNasdaq]{2,111}[MarketSP500]{1,127}<<
135847.64 1 RVreplace start: [$RV[MarketNASDAQ]]
135847.64 1 RVreplace end: [2,111]
135847.65 1 [say NASDAQ] Say numbers: 2,111 as Number
135847.65 1 fn PlaySoundStartNumbers IpNasdaq.wav, , 2,111, Number
135847.67 1 sVbsFunctionToUse=Number
135847.74 1 Started SayNumber VBScript OK. (E:\Program Files\VoiceGuide\data\vbs_1_SayNumber.vbs)
135847.86 1 cl Play_Start E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpNasdaq.wav,2.wav,thousand.wav,1.wav,hundred.wav,11.wav
135848.29 1 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpNasdaq.wav,E:\Program Files\VoiceGuide\system\voice\2.wav,E:\Program Files\VoiceGuide\system\voice\thousand.wav,E:\Program Files\VoiceGuide\system\voice\1.wav,E:\Program Files\VoiceGuide\system\voice\hundred.wav,E:\Program Files\VoiceGuide\system\voice\11.wav]
135854.29 1 Play End line[1] (id=163694)
135854.29 1 LsSayNbrPlay EV_PLAY_FINISHED
135854.30 1 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
135854.30 1 RVreplace start: [$RV[MarketDOW]]
135854.31 1 RVreplace end: [10,485]
135854.31 1 [say DOW] Say numbers: 10,485 as Number
135854.32 1 fn PlaySoundStartNumbers IpDow.wav, , 10,485, Number
135854.33 1 sVbsFunctionToUse=Number
135854.40 1 Started SayNumber VBScript OK. (E:\Program Files\VoiceGuide\data\vbs_1_SayNumber.vbs)
135854.49 1 cl Play_Start E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpDow.wav,10.wav,thousand.wav,4.wav,hundred.wav,80.wav,5.wav
135854.74 1 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpDow.wav,E:\Program Files\VoiceGuide\system\voice\10.wav,E:\Program Files\VoiceGuide\system\voice\thousand.wav,E:\Program Files\VoiceGuide\system\voice\4.wav,E:\Program Files\VoiceGuide\system\voice\hundred.wav,E:\Program Files\VoiceGuide\system\voice\80.wav,E:\Program Files\VoiceGuide\system\voice\5.wav]
135901.56 1 Play End line[1] (id=170324)
135901.57 1 LsSayNbrPlay EV_PLAY_FINISHED
135901.57 1 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
135901.60 1 RVreplace start: [$RV[MarketSP500]]
135901.61 1 RVreplace end: [1,127]
135901.61 1 [say SP500] Say numbers: 1,127 as Number
135901.62 1 fn PlaySoundStartNumbers IpSP500.wav, , 1,127, Number
135901.63 1 sVbsFunctionToUse=Number
135901.70 1 Started SayNumber VBScript OK. (E:\Program Files\VoiceGuide\data\vbs_1_SayNumber.vbs)
135901.79 1 cl Play_Start E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpSP500.wav,1.wav,thousand.wav,1.wav,hundred.wav,20.wav,7.wav
135902.02 1 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpSP500.wav,E:\Program Files\VoiceGuide\system\voice\1.wav,E:\Program Files\VoiceGuide\system\voice\thousand.wav,E:\Program Files\VoiceGuide\system\voice\1.wav,E:\Program Files\VoiceGuide\system\voice\hundred.wav,E:\Program Files\VoiceGuide\system\voice\20.wav,E:\Program Files\VoiceGuide\system\voice\7.wav]
135909.59 1 Play End line[1] (id=177614)
135909.61 1 LsSayNbrPlay EV_PLAY_FINISHED
135909.61 1 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
135909.63 1 [Goodbye] Playing
135909.63 1 [Goodbye] Playing (IpGoodbye.wav)
135909.95 1 PlaySoundStart ok [E:\Program Files\VoiceGuide\Scripts\Internet Portal\IpGoodbye.wav]
135909.95 1 RunModule PLAY end
135912.25 1 Play End line[1] (id=185445)
135912.26 1 LsPlayMsg EV_PLAY_FINISHED
135912.26 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
135912.27 1 Hanging up call... [Hangup Module]
135912.28 1 RecSoundStop ok
135912.28 1 PlaySoundStop ok
135912.29 1 fnHangupCall end
135914.27 1 Hanging up call...(2)
135914.28 1 RecSoundStop ok
135914.28 1 PlaySoundStop ok
135914.28 1 fnHangupCall end
135914.29 1 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
135914.30 1 tapi Reply (LineEvReply) ok 66512 0
135914.75 1 callstate DISCONNECTED 66426,1,0
135914.75 1 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
135914.76 1 Hanging up call...
135914.76 1 RecSoundStop ok
135914.76 1 PlaySoundStop ok
135914.77 1 fnHangupCall end
135914.77 1 callstate IDLE 66426 0 0
135914.78 1 WorkingMode@Idle=
135914.79 1 tapi Reply (LineEvReply) ok 66494 0
135914.80 1 tapi Reply (LineEvReply) ok 66477 0
135915.70 1 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
135915.71 1 ReinitTelephony due to IDLE start
135915.71 1 tapic lineDeallocateCall(MainCall:66426) 0
135915.74 1 lineOpen(1) => 0
135915.74 1 Waiting for a call...
135915.75 1 lineOpen(1)LineHandle=66290
Trace shows that the modem drivers have reported that the modem has hung up the call promptly:
This is definitely a telco problem (albeit an unusual one...). I'd suggest contacting them about it...
I am also testing the trial version and I have exactly the same problem. I have only tested the scripts calling from a mobile, maybe it will be better if i tested calling from another land line.
I am using a zoom internal voice modem.
UK, BT landline
I will also post a log here later.
regards
Dan
