Vg Agent - Popup Sizing
Is there a way to widen the size of the VG Agent popup? It wraps around the text and I need it just a little wider.
Agent can manually change the size and position of their popup window any time.
Also, if the popup window is closed the next time it is 'popped' open again (ie. made visible again) it will be the same size and in the same place as it was when it was closed.
If you really must have the default starting size altered then we can add a setting to vgAgent.ini file that will let you set the starting size of the popup window.
Yes, an option in the .ini file would be nice. our users want to have everything just right without doing any work. Also it will make it look more professional from our end.
Thanks!
In next release of vgAgent you can add this section like this to the vgAgent.ini file:
[PopUp]
Height=800
Width=500
the popups intial size will be set accordingly.
(you can use your own valued for width height).
