Guest cargonet Report post Posted 06/14/2013 05:51 AM Dear Support Officer We no have a request from customer that, they want slightly more complex login when the calling into the voice system. before: calling-> press 1 for function link to database, press 2-5 transfer call to extention -> if transfer failed, will fail back into the main menu. after calling-> press 1 .... 2-5 ... > if the transfer failed, can anounce the line is busy, continue to hold or press to back main menu or press to end the call especially a request on if the first transfer failed, can continue to another transfer (2nd try) Kindly advice how this can be achieved. Thanks so much Kevin Share this post Link to post
SupportTeam Report post Posted 06/14/2013 08:39 AM If a transfer fails then the "Transfer Call" module will take a 'fail' path. The fail path can then point to a Play module that will play the "line is busy..." message, and then can move onto other modules (and another transfer attempt eventually). Please see: http://www.voiceguide.com/vghelp/source/html/modxfer.htm You should use a 'Monitored' or 'Announced' type of transfer (not 'Blind') Share this post Link to post
