mikeraut Report post Posted 06/21/2013 06:31 AM Tested the 2 line recording module, and I can't seem to get it to work to test recording. Get a vb error when executing the \temp\vbscript 0621_ktTel.zip Config.zip Share this post Link to post
SupportTeam Report post Posted 06/21/2013 07:03 AM In the VBScript in module [start 2 line Dial] please change: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_2], "c:\MyRecFile.wav", "") to: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "c:\MyRecFile.wav", "") Please see: http://www.voiceguide.com/vghelp/source/html/com_record_2lines_start.htm Share this post Link to post
mikeraut Report post Posted 06/21/2013 09:20 AM Thanks, the example now works. Would like to suggest a working example in the next build of VG for the 2 line recording vgs file. Share this post Link to post
SupportTeam Report post Posted 06/21/2013 10:36 AM Have fixed the sample that was shipping in latest versions of v7. Regarding the ACD call recording: The current Config.xml ACD entry is: <acd> <callrecord_dir>C:\calls\sales</callrecord_dir> </acd> Here is sample of what that section should look like: <acd> <queues> <queue> <name>sales</name> <paths> on {timeout 1200} goto [Voicemail box 0001] on {1} goto [sales opt1 selected] </paths> <callrecord_dir>C:\acdlog1</callrecord_dir> </queue> <queue> <name>accounts</name> <paths> on {timeout 1200} goto [Voicemail box 0002] on {1} goto [accounts_self_service] </paths> <callrecord_dir>C:\acdlog2</callrecord_dir> </queue> </queues> </acd> The callrecord_dir is set on a per-queue basis Share this post Link to post
