mikeraut Report post Posted 06/27/2013 07:01 AM I have a 12-port ACD system, inbound. Lines 7 to 12 are set <AllowDialOut>1</AllowDialOut> vg.ini is set to [VGDialer] FreePortSearchOrder=1 VG reports that there is no line available. Please advise no line available.zip ConfigLine.zip Share this post Link to post
SupportTeam Report post Posted 06/27/2013 08:56 AM Looks like the module that places the call in the ACD queue also specified the list of ports on which the outgoing leg of the call is allowed to be made. Only one port is specified (port 1) and that port is one of the ports on which the outgoing dialing was disabled in Config.xml Recommend to not specify the port selection list in the Transfer Call module for now. If you continue to have problems please post the script file that is being used. From vgEngine log: 075707.948 6 Search for free ports in list [1] src=XferDialAndConf 075707.948 6 1 1 CallExistsOnLine TRUE crn=10000001 075707.948 6 2 2 CallExistsOnLine FALSE crn=0 075707.948 6 2 2 dial FindFreeLine: iDialoutsEnabledOnThisLine=0 075707.948 6 4 3 CallExistsOnLine FALSE crn=0 075707.948 6 4 3 dial FindFreeLine: iDialoutsEnabledOnThisLine=0 075707.948 6 6 4 CallExistsOnLine FALSE crn=0 075707.948 6 6 4 dial FindFreeLine: iDialoutsEnabledOnThisLine=0 075707.948 6 8 5 CallExistsOnLine FALSE crn=0 075707.948 6 8 5 dial FindFreeLine: iDialoutsEnabledOnThisLine=0 075707.948 6 10 6 CallExistsOnLine FALSE crn=0 075707.948 6 10 6 dial FindFreeLine: iDialoutsEnabledOnThisLine=0 075707.948 6 12 7 CallExistsOnLine FALSE crn=0 075707.948 6 12 7 dial device [dxxxB2C3,dxxxB2C3] not in selection list [,1,] 075707.949 6 14 8 CallExistsOnLine FALSE crn=0 075707.949 6 14 8 dial device [dxxxB2C4,dxxxB2C4] not in selection list [,1,] 075707.949 6 16 9 CallExistsOnLine FALSE crn=0 075707.949 6 16 9 dial device [dxxxB3C1,dxxxB3C1] not in selection list [,1,] 075707.949 6 18 10 CallExistsOnLine FALSE crn=0 075707.949 6 18 10 dial device [dxxxB3C2,dxxxB3C2] not in selection list [,1,] 075707.949 6 20 11 CallExistsOnLine FALSE crn=0 075707.949 6 20 11 dial device [dxxxB3C3,dxxxB3C3] not in selection list [,1,] 075707.949 6 22 12 CallExistsOnLine FALSE crn=0 075707.949 6 22 12 dial device [dxxxB3C4,dxxxB3C4] not in selection list [,1,] 075707.949 6 1 1 Could not find free line to place outgoing call. Share this post Link to post
mikeraut Report post Posted 06/27/2013 09:10 AM Looks like the module that places the call in the ACD queue also specified the list of ports on which the outgoing leg of the call is allowed to be made. Only one port is specified (port 1) and that port is one of the ports on which the outgoing dialing was disabled in Config.xml Recommend to not specify the port selection list in the Transfer Call module for now. If you continue to have problems please post the script file that is being used. I have not specified the port at all as there is NO place to actually specify the port within vg. I will attach the script Similar problem existed before and a patch was written...http://voiceguide.com/forums/index.php?showtopic=8794&hl=dialer&do=findComment&comment=35061 Acd.vgs Share this post Link to post
SupportTeam Report post Posted 06/27/2013 09:32 AM Please see attached image. Arrow points to where the port selection list is specified in the "Transfer to Pickups" module. (the "Transfer to Queries" module has similar setting so you should change that module as well) The thread to which the link was posted is not a similar problem. The port for outgoing leg of call was being found in that thread. The question in that thread referred to free port search order. Also, in ACD calls the call recording is done using the "callrecord_dir" entry in Config.xml As per post here: http://voiceguide.com/forums/index.php?showtopic=10281&do=findComment&comment=37719 Record_2Lines_Start calls should not be used to do ACD call recording. Share this post Link to post
