Comparing Dates
Hi support team,
I'm trying to compare dates which the output will be TRUE if date stored in database is bigger than current date, otherwise is false. I use evaluate expression module to achieve this but I get some error here. Please guide me.
084231.446 6 64 22 state [Leader_Qualify1] Evaluate [$RV[Get_Leader_Tablename_enqdate2] >= #$RV_MONTH/$RV_DATE/$RV_YEAR#]
084231.446 6 64 22 rv replace start [$RV[Get_Leader_Tablename_enqdate2] >= #$RV_MONTH/$RV_DATE/$RV_YEAR#]
084231.446 18 64 22 db odbc query completed.
084231.446 6 64 22 rv replace end [8/31/2013 12:00:00 AM >= #7/7/3/2013 8:42:31 AM/2013#]
084231.446 6 64 22 eval [8/31/2013 12:00:00 AM >= #7/7/3/2013 8:42:31 AM/2013#]
084231.447 6 64 22 VGMTYPE_EVALEXPR InvokeMember Eval Exception : Exception has been thrown by the target of an invocation.
084231.447 6 64 22 eval InvokeMember Eval returned
084231.447 6 64 22 rvns add Leader_Qualify1_Input|8/31/2013 12:00:00 AM >= #7/7/3/2013 8:42:31 AM/2013#
084231.447 6 64 22 rvns add Leader_Qualify1|
084231.448 6 64 22 Eval Expr result:[]
084231.448 6 64 22 path {} not found
084231.448 6 64 22 matching path not found [], try boolean paths.
You should use DateDiff function.
If your dates are in MM/DD/YYYY format then this should work:
DateDiff("d", "$RV[Get_Leader_Tablename_enqdate2]", "$RV_MM/$RV_DD/$RV_YEAR") <= 0
and then True/success path will be taken from the Evaluate Expression moudule when $RV[Get_Leader_Tablename_enqdate2] is in future of current time (or same).
You can use attached VBScript file to test out the DateDiff function for yourself.
fromDate="8/31/2013 12:00:00 AM"
toDate="01/05/2013"
iResult = DateDiff("d",fromDate,toDate)
if iResult < 0 then
  MsgBox "toDate is before fromDate : " & iResult
end if
if iResult > 0 then
  MsgBox "toDate is after fromDate : " & iResult
end if
if iResult = 0 then
  MsgBox "same date"
end if
