Vg.script_goto Error, Partially Works
Hello
I've got a VB script as follows:
vg.Admin_TraceLogAdd 0, 0, "menu -"
set vg = Nothing
if $RV[Zapytanie_1_1]=$RV[Podaj haslo] then
vg.Admin_TraceLogAdd 0, 0, "goto - "
set vg = Nothing
vg.Script_Goto $RV_LINEID, "menu.vgs", "menu","[index]{$RV[Indeks]}[semestr]{$RV[semestr]}"
set vg = Nothing
else
vg.Run_ResultReturn $RV_LINEID, "fail"
set vg = Nothing
end if
it is supossed to run menu.vgs
condition is true (in log goto -).
it writes to a log that menu.vgs was executed and a wave file was generated (the file is really on disk, and it's correct) but the call is cancelled (hang up)
you don't hear a generated file at all (it should say text)
menu.vgs should play a tts generated text 3 times
Could you help me?
here come the log file
152945,78  8 [dobre haslo?] Running VB Script...
152945,78  8 RVreplace start (strlen>100)
152945,80  8 Run Script waiting... (shellid=1996, process=1512)
152945,83  0 menu -
152945,83  0 goto -
152945,84  8 cl    Script_Goto 8, menu.vgs, menu,"menu -"
152945,84  2 tr    NewVgsVgm_Goto menu.vgs,menu,"menu -",,,0
152945,84  0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\infolinia\menu.vgs at idx=4
152945,84  2 tr    NewVgsVgm_Goto 1
152945,84  2 tr    NewVgsVgm_Goto 2
152945,84  8 [menu] Playing
152945,84  8 tts generate start[<p><RATE SPEED="-1">text</RATE></p>]
152946,85  8 tts generate end
152946,85  8 [menu] Playing (C:\Program Files\VoiceGuide\data\tts8.wav)
152946,85  8 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts8.wav]
152946,85  8 RunModule PLAY end
152946,85  2 tr    NewVgsVgm_Goto end
152946,86  8 dtmf *   (66175,42,2)
152946,86  8 LsPlayMsg *
152946,97  8 PlaySoundStop ok
152946,98  8 Hanging up call... [Hangup Module]
Best regards
Dominik
Trace shows that the TTS system generated an empty file - you should be able to confirm this by looking at the C:\Program Files\VoiceGuide\data\tts8.wav
Please try specifying just
text
in the TTS field for now, rather then
Maybe your TTS engine cannot correctly interpret the <RATE SPEED="-1"> XML tag...
The VBScript itself looks fine. You can reduce the line count a bit by just creating the "VoiceGuide.CommandLink" object once, ie:
else
end if
set vg = Nothing
Which version of VG are you using (v5.1.7 or some older one?)
I'm using VG 5.1.7001
tts8.wav is correctly generated, i can hear text
What can be wrong?
PS. thanks for a tip.
Best wishes,
Dominik
If you can hear sound OK when you use:
text
this means that the TTS engine that is installed on your system does not know how to generate TTS when supplied with input like
What TTS engine is installed?
Please read the TTS engine's manual to see what input it does accept...
Both cases work properly.
vs.
text
first one is a bit slower so the XML tag is recognized
I'm using Elan tempo demo version
Best wishes,
Dominik
