Unexpected Hang Up.
Hello, for some reason my scrip will hang up in Play module. I notice those play module that has timeout on path case this problem. I test the Play module in a new script and the problem didn’t accrued. This is why I can not think of any other possible reason why my script unexpectedly hangs up.
202924.90 1 state [PayamBadie] Playing
202924.90 1 state [PayamBadie] Playing (C:\Program Files\IVR Masseging and Recharging phone\Sound files\PayameBadie.wav)
202924.90 1 timer clear bForceClear=False
202925.76 1 play start ok, lPlayId=269863
202925.77 0 comlg trace point delete
202925.79 1 cl Run_ResultReturn [[fileStatus]{Success}]
202925.79 1 rvns add [fileStatus]{Success}
202925.79 1 cl Run_ResultReturn iRunWait_VgmIdx=14, iVgmIdx_Curr=23
202925.79 1 HangupCall start (Run_ResultReturn - no path match (diff vgm))
202925.79 1 rv add [Hangup Time]{7/10/2013 8:29:25 PM}
As you notice at line 202925.79 1 HangupCall start (Run_ResultReturn - no path match (diff vgm))
But I do have path: on {timeout 2} goto [PlayPayam]
Please see attached my log file for this error.
LOGFILE.ZIP
You are using VoiceGuide v6.
Please change all "Run VBScript" type modules in VoiceGuide v6 to "Wait until VBScript completes".
