invoso.com Report post Posted 07/12/2013 10:10 AM Source xml data : <methodResponse> <params> <param> <value> <struct> <member> <name>stanKonta</name> <value> <string>ACTIVE</string> </value> </member> <member> <name>saldoKonta</name> <value> <string>95.39</string> </value> </member> </struct> </value> </param> </params> </methodResponse> How to find VG variables names in this case? Share this post Link to post
SupportTeam Report post Posted 07/13/2013 02:14 AM Can you please provide more information as to what the above relates to? can you post the script that is used and the vgEngine trace file that captures the call? Share this post Link to post
invoso.com Report post Posted 07/16/2013 06:24 AM log data: 080401.930 6 2 1 RunModule start Web Service, [Web Service 1], iModuleIdx=168, previous: vgm=168, vgs=2:2 080401.930 6 2 1 state [Web Service 1] Web Service Call 080401.930 6 2 1 t timer set 10 sec : EV_TIMEOUT_GOTOMODULE 080401.930 6 2 1 QueueUserWorkItem modWs.RunModule call 080401.931 6 2 1 zModParams.iLineId=2, zModParams.iModuleIdx=168 080401.931 3 2 1 ws RunModule start iLineId=2, iModuleIdx=168, iRunWait=1 080401.931 3 2 1 ws PlayOnHoldFile 080401.931 3 2 1 moh file not specified 080401.931 3 2 1 ws WebRequest.Create returned [http://www.twoje.infolinie.com/wm/adv.xml ] 080401.940 3 2 1 ws request.Method=GET 080401.940 3 2 1 ws CurrentConnections=0/60, ReceiveBufferSize=-1, Expect100Continue=True 080401.940 3 2 1 ws ConnectionLeaseTimeout=180000 080401.940 3 2 1 ws spm.DefaultConnectionLimit=60, spm.DefaultPersistentConnectionLimit=2 080401.940 3 2 1 ws new RequestState call 080401.940 3 2 1 ws BeginGetResponse (GetWsResponse_Callback) call. ReadWriteTimeout=8000 080401.970 3 2 1 ws BeginGetResponse returned 080401.981 24 2 1 ws GetResponse_Callback start. Time since WsUserWorkItemCreated=00:00:00.0510030 080401.981 24 2 1 ws header Connection 0 = close 080401.981 24 2 1 ws header Accept-Ranges 0 = bytes 080401.981 24 2 1 ws header Content-Length 0 = 429 080401.981 24 2 1 ws header Content-Type 0 = application/xml 080401.981 24 2 1 ws header Date 0 = Tue, 16 Jul 2013 06:04:07 GMT 080401.981 24 2 1 ws header ETag 0 = "268000000020b2f-1ad-4e19ab8c32e13" 080401.981 24 2 1 ws header Last-Modified 0 = Tue, 16 Jul 2013 06:02:27 GMT 080401.981 24 2 1 ws header Server 0 = Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t 080401.982 24 2 1 ws header scan returns: [] 080401.982 24 2 1 ws header list returns: [[Web Service 1_http_resp_hdr_Connection]{close}[Web Service 1_http_resp_hdr_Accept-Ranges]{bytes}[Web Service 1_http_resp_hdr_Content-Length]{429}[Web Service 1_http_resp_hdr_Content-Type]{application/xml}[Web Service 1_http_resp_hdr_Date]{Tue, 16 Jul 2013 06:04:07 GMT}[Web Service 1_http_resp_hdr_ETag]{"268000000020b2f-1ad-4e19ab8c32e13"}[Web Service 1_http_resp_hdr_Last-Modified]{Tue, 16 Jul 2013 06:02:27 GMT}[Web Service 1_http_resp_hdr_Server]{Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t}] 080401.982 24 2 1 ws ListHeadersAndReturnSomeRVs returned. sRV=[Web Service 1_http_resp_hdr_Connection]{close}[Web Service 1_http_resp_hdr_Accept-Ranges]{bytes}[Web Service 1_http_resp_hdr_Content-Length]{429}[Web Service 1_http_resp_hdr_Content-Type]{application/xml}[Web Service 1_http_resp_hdr_Date]{Tue, 16 Jul 2013 06:04:07 GMT}[Web Service 1_http_resp_hdr_ETag]{"268000000020b2f-1ad-4e19ab8c32e13"}[Web Service 1_http_resp_hdr_Last-Modified]{Tue, 16 Jul 2013 06:02:27 GMT}[Web Service 1_http_resp_hdr_Server]{Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t} 080401.982 24 2 1 ws response.GetResponseStream call 080401.982 24 2 1 ws sreaderResponse.ReadToEnd completed 080401.982 24 2 1 ws strReturnedByByHttpResponse XML parse 080401.983 24 2 1 rv add start Web Service 1_Result_Code|OK 080401.983 24 2 1 rv add OK 080401.983 24 2 1 rv add start Web Service 1_Result_Desc|OK 080401.983 24 2 1 rv add OK 080401.983 24 2 1 ws GetWsResponse_Callback iRunWait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0 080401.983 24 2 1 ModuleCompleted_WebServiceCall [200] : [OK] 080401.983 24 2 1 path {200} not found 080401.983 24 2 1 path {OK} not found 080401.984 24 2 1 path {OK} not found 080401.984 24 2 1 FindNextVgmTitleInPathList: next module title is=[Evaluate 26] Getting data from other xml files I don't see any data too. I have to use Evaluate Expression to call data if i know their names. adv.xml Share this post Link to post
SupportTeam Report post Posted 07/16/2013 11:03 AM Looks like you are using a Web Service type module to retrieve XML data from URL http://www.twoje.infolinie.com/wm/adv.xml using a GET request. The trace excerpt posted was a bit to short to determine which version of VoiceGuide is used but when we ran this using the latest version the following RVs were created: 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Connection|close 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Accept-Ranges|bytes 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Content-Length|429 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Content-Type|application/xml 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Date|Tue, 16 Jul 2013 10:59:00 GMT 205908.322 18 82 32 rv add ourTest_http_resp_hdr_ETag|"268000000020b2f-1ad-4e19ab8c32e13" 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Last-Modified|Tue, 16 Jul 2013 06:02:27 GMT 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Server|Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t 205908.322 18 82 32 rv add name|stanKonta 205908.322 18 82 32 rv add name_1|stanKonta 205908.322 18 82 32 rv add string|ACTIVE 205908.322 18 82 32 rv add string_1|ACTIVE 205908.322 18 82 32 rv add name_2|saldoKonta 205908.322 18 82 32 rv add string_2|95.39 205908.322 18 82 32 rv add ourTest_Result_Code|OK 205908.322 18 82 32 rv add ourTest_Result_Desc|OK eg: $RV[string_2] would hold a value of: 95.39 fuller trace: 205905.053 3 82 32 state [ourTest] Web Service Call 205905.053 3 82 32 modWs SetTimeoutEventInVgm->-1 205905.053 3 82 32 t timer set 30 sec : EV_TIMEOUT_HANGUP 205905.054 3 82 32 QueueUserWorkItem modWs.RunModule call. modCurrentModuleWs.hash=11454272, zModTaskParams.hash=1680636826 205905.054 3 82 32 q scr run evScriptEvent sCode=[TDX_CST] iActionID=0, crn=10000002[16100|0|0|0|0][DE_LCON|||||] 00:00:00.0019532 max:3|00:00:00.1113282 205905.054 3 82 32 scriptevent TDX_CST 16100|0|0 DE_LCON|| LineState=LS_WS_CALL 205905.054 3 82 32 LsWsCall TDX_CST lCode2Str=EV_UNKNOWN_134 205905.054 3 82 32 ws ScriptEvent EV_UNKNOWN_134,TDX_CST 16100,0,0 DE_LCON|| 205905.054 3 82 32 ws ScriptEvent taskParams.hash=1680636826 205905.054 3 82 32 ws ScriptEvent ignored as bReadyToHandleEvents=false 205905.054 17 82 32 ws RunModule_WebService start iModuleIdx=528, iRunWait=1 205905.054 17 82 32 ws sLogFromConstructor: taskParams_in.hash=1680636826, taskParams.hash=1680636826 205905.054 17 82 32 ws RunModule_WebService start taskParams.hash=1680636826 205905.054 17 82 32 ws PlayOnHoldFile 205905.054 17 82 32 moh file not specified 205905.054 17 82 32 ws WebRequest.Create [http://www.twoje.infolinie.com/wm/adv.xml ] call 205905.055 17 82 32 ws request.Method=[GET] 205905.055 17 82 32 ws request.ServicePoint.CurrentConnections call. 205905.055 17 82 32 ws CurrentConnections=0/60, ReceiveBufferSize=-1, Expect100Continue=False 205905.055 17 82 32 ws sp.ConnectionLeaseTimeout=0, spm.DefaultConnectionLimit=60, spm.DefaultPersistentConnectionLimit=2 205905.055 17 82 32 ws new RequestState call 205905.055 17 82 32 ws request.ReadWriteTimeout=30000, taskParams.iWsTimeoutMs_GoToAnotherModule=-1 205905.055 17 82 32 ws taskParams.clsRequestState.hash=35992504 205905.055 17 82 32 ws BeginGetResponse (GetWsResponse_Callback) call. ReadWriteTimeout=30000 205905.056 17 82 32 ws BeginGetResponse returned 205908.321 18 82 32 ws GetWsResponse_Callback start. class' taskParams.hash=1680636826 clsRequestStateData.taskParams.hash=1680636826 205908.321 18 82 32 ws GetWsResponse_Callback request.hash=46599775 205908.321 18 82 32 ws GetWsResponse_Callback start [ourTest], time since WsUserWorkItemCreated=00:00:03.2666015 205908.321 18 82 32 ws header Connection 0 = close 205908.321 18 82 32 ws header Accept-Ranges 0 = bytes 205908.321 18 82 32 ws header Content-Length 0 = 429 205908.322 18 82 32 ws header Content-Type 0 = application/xml 205908.322 18 82 32 ws header Date 0 = Tue, 16 Jul 2013 10:59:00 GMT 205908.322 18 82 32 ws header ETag 0 = "268000000020b2f-1ad-4e19ab8c32e13" 205908.322 18 82 32 ws header Last-Modified 0 = Tue, 16 Jul 2013 06:02:27 GMT 205908.322 18 82 32 ws header Server 0 = Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t 205908.322 18 82 32 ws header scan returns: [] 205908.322 18 82 32 ws header list returns: [[ourTest_http_resp_hdr_Connection]{close}[ourTest_http_resp_hdr_Accept-Ranges]{bytes}[ourTest_http_resp_hdr_Content-Length]{429}[ourTest_http_resp_hdr_Content-Type]{application/xml}[ourTest_http_resp_hdr_Date]{Tue, 16 Jul 2013 10:59:00 GMT}[ourTest_http_resp_hdr_ETag]{"268000000020b2f-1ad-4e19ab8c32e13"}[ourTest_http_resp_hdr_Last-Modified]{Tue, 16 Jul 2013 06:02:27 GMT}[ourTest_http_resp_hdr_Server]{Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t}] 205908.322 18 82 32 ws GetWsResponse_Callback ListHeadersAndReturnSomeRVs returned. sRV=[ourTest_http_resp_hdr_Connection]{close}[ourTest_http_resp_hdr_Accept-Ranges]{bytes}[ourTest_http_resp_hdr_Content-Length]{429}[ourTest_http_resp_hdr_Content-Type]{application/xml}[ourTest_http_resp_hdr_Date]{Tue, 16 Jul 2013 10:59:00 GMT}[ourTest_http_resp_hdr_ETag]{"268000000020b2f-1ad-4e19ab8c32e13"}[ourTest_http_resp_hdr_Last-Modified]{Tue, 16 Jul 2013 06:02:27 GMT}[ourTest_http_resp_hdr_Server]{Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t} 205908.322 18 82 32 ws response.GetResponseStream call 205908.322 18 82 32 ws sreaderResponse.ReadToEnd completed 205908.322 18 82 32 ws strReturnedByByHttpResponse XML parse 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Connection|close 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Accept-Ranges|bytes 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Content-Length|429 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Content-Type|application/xml 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Date|Tue, 16 Jul 2013 10:59:00 GMT 205908.322 18 82 32 rv add ourTest_http_resp_hdr_ETag|"268000000020b2f-1ad-4e19ab8c32e13" 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Last-Modified|Tue, 16 Jul 2013 06:02:27 GMT 205908.322 18 82 32 rv add ourTest_http_resp_hdr_Server|Apache/2.2.22 (Win32) PHP/5.2.17 mod_ssl/2.2.22 OpenSSL/0.9.8t 205908.322 18 82 32 rv add name|stanKonta 205908.322 18 82 32 rv add name_1|stanKonta 205908.322 18 82 32 rv add string|ACTIVE 205908.322 18 82 32 rv add string_1|ACTIVE 205908.322 18 82 32 rv add name_2|saldoKonta 205908.322 18 82 32 rv add string_2|95.39 205908.322 18 82 32 rv add ourTest_Result_Code|OK 205908.322 18 82 32 rv add ourTest_Result_Desc|OK 205908.322 18 82 32 ws GetWsResponse_Callback iRunWait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0 205908.322 18 82 32 ModuleCompleted_WebServiceCall [200] : [OK] 205908.322 18 82 32 path {200} not found 205908.322 18 82 32 path {OK} not found 205908.323 18 82 32 path {OK} not found 205908.323 18 82 32 HangupCall_AddToTaskQueue (ModuleCompleted_WebServiceCall_OK) Share this post Link to post
invoso.com Report post Posted 07/16/2013 11:20 AM Version I use: 141720.520 5 ------------------------------------------------------------------------------------------------------ 141720.520 5 vgEngine version : 0.0.0.0 (RELEASE Build) 141720.520 5 created on : 2013-05-02 23:45:07.90 141720.520 5 AssemblyLocation : C:\Program Files (x86)\VoiceGuide\vgEngine.dll 141720.520 5 LastWriteTime : 2013-05-02 15:46:40 141720.520 5 trace lvl=10, encoding=System.Text.ASCIIEncoding (ASCII) And I use HTTP GET REQUEST Can You send script You use to test? Share this post Link to post
SupportTeam Report post Posted 07/16/2013 11:25 AM Please see attached VoiceGuide script file. testWs.vgs Share this post Link to post
SupportTeam Report post Posted 07/16/2013 11:39 AM Current latest daily build of v7 can be found here: [old link removed] Share this post Link to post
