rmatosaw Report post Posted 07/31/2013 02:41 AM Please, we have problem to send fax. - we are trying to send fax from one channel to another in the same board. - the process appears to be ok (the second channel answers, the process is started) - but the process continues until 46 seconds receiving. The channel stops, the tiff file received has only 1 Kb (with error) and the caller channel do not stops. When we tried to send to a "real" fax machine the problem appears to be the same: the channel keeps buzy, but the machine do not process anything. I attached the ConfigLine.xml, the last log files etc (please refer to number 40815301 - the receiving channel number). Thanks for your help. FAX_ERRO.zip Share this post Link to post
SupportTeam Report post Posted 08/03/2013 10:26 AM Log traces shows that Dialogic cannot send the supplied TIF file as the .TIF file is in wrong format: 074014.141 7 11 6 ev Dialogic 0,TFX_FAXSEND_ERROR, crn=20000001, 276,0,0,fx_sendfax error,Bad TIFF/F header, 074014.141 7 11 6 q scr add evScriptEvent 0 TFX_FAXSEND_ERROR 074014.141 6 11 6 q scr run evScriptEvent sCode=[TFX_FAXSEND_ERROR] iActionID=0, crn=20000001[276|0|0|0|0][fx_sendfax error|Bad TIFF/F header||||] 00:00:00 max:4|00:00:00.0312500 074014.141 6 11 6 scriptevent TFX_FAXSEND_ERROR 276|0|0 fx_sendfax error|Bad TIFF/F header| LineState=LS_FAX_TX 074014.141 6 11 6 LsFaxTx TFX_FAXSEND_ERROR 276 fx_sendfax error 994 074014.141 1200 11 fn Fax_Tx_Start(sFileList=C:\FAXENVIO\20110613143141797.tif, sHdr2=, sOptions=) 995 074014.141 1200 11 Fax_Tx_Start(strSoundFile=[C:\FAXENVIO\20110613143141797.tif], sHdr1_LocalId=[], sHdr1_User=[VoiceGuide], sHdr2=[], sOptions=[]) 996 074014.141 1200 11 fax Fax_Tx_Start_Now begin 997 074014.141 1200 11 fax Clean_iottFax_chain 998 074014.141 1200 11 fax strFnameRetreived=[C:\FAXENVIO\20110613143141797.tif] 999 074014.141 1200 11 fax iFnameLength=33 000 074014.141 1200 11 fax strFnameRetreived+(iFnameLength-5)=[7.tif] 001 074014.141 1200 11 fax file suffix indicates input file [C:\FAXENVIO\20110613143141797.tif] is TIFF 002 074014.141 1200 11 fax open(C:\FAXENVIO\20110613143141797.tif) => 5 - opened ok 003 074014.141 1200 11 fax fx_initstat(12, DF_TX) => 0 004 074014.141 1200 11 fax fx_setparm (12, FC_LOCALID) ok 005 074014.141 1200 11 fax fx_setparm (12, FC_HDRATTRIB) ok 006 074014.141 1200 11 fax fx_setparm (12, FC_FONT3) ok 007 074014.141 1200 11 fax fx_setparm (12, FC_FONT3) ok 008 074014.141 1200 11 fax fx_setparm (12, FC_HDRUSER) ok 009 074014.141 1200 11 fax fx_setparm (12, FC_HDRUSER2) ok 010 074014.141 1200 11 fx_sendfax (12, 0EFD0C6C, EV_ASYNC) => -1, err=276:Bad TIFF/F header, hli=0EFCCA88 011 074014.141 1200 11 fax unhandled ATDV_LASTERR=276 012 074014.141 1200 11 r Dialogic TFX_FAXSEND_ERROR 0 (276 0 0 fx_sendfax error Bad TIFF/F header ) TIF files for Fax sending must be of specific resolution. From http://www.voiceguide.com/vghelp/source/html/fax_intro.htm : Quote The TIFF file must be in "Fax Group 3" format and have a horizontal resolution of 1728 pixels across the page. Vertical pixel count will depends on length of fax page, but a standard page is 2200 pixels long. The DPI resolution of the TIFF file should be 200. Can you .ZIP up and post the C:\FAXENVIO\20110613143141797.tif file from your system? Unzip attachment to get a sample .TIF file that can be faxed. (it is the same file that is provided with VoiceGuide sample fax send/receive scripts in VoiceGuide's \Scripts\Fax\ subdirectory. TestFax.zip Share this post Link to post
rmatosaw Report post Posted 08/03/2013 12:41 PM Sorry.I had not read the log with proper care.Everything ok now.Thank you. Share this post Link to post
