Isdn To Dialogic?
That adaptor should be fine.
Dialogic does not have a BRI card as part of its current lineup, so to attach to a BRI digital line (2B+D channel service) you will need to use a TA (Terminal Adaptor) and an analog Dialogic card.
Dialogic does make Digital cards to connect to E1 ISDN and T1 ISDN trunks, and if lower line counts are required then both T1 and E1 can be provided as 'fractional' - eg: 10 lines on an E1 (instead of usual 30)
