Guest u4910 Report post Posted 09/04/2013 02:01 PM Have the dispositions changed in the last version of VG? It seems the answered is not broken down by human or machine. Also I can't tell which are SIT. Thanks, Here are my recent dispositions by count: ANSWERED 1303 NOANSWER 273 NOTCONTACTED 672 Here are a more historical disposition by count before going to the current version. ANSWERED 2056 ANSWERED_HUMAN 4042 ANSWERED_MACHINE 6399 ANSWERED_NORINGBACK 14 ANSWERED_UNDETERMINED 33 BUSY 530 NOANSWER 2053 NOTCONTACTED 814 SIT 2539 Share this post Link to post
SupportTeam Report post Posted 09/04/2013 06:24 PM Which version is currently installed on the system? Can you please post a vgEngine trace capturing an outgoing call on the system? (Please .ZIP up traces before posting) Share this post Link to post
Guest u4910 Report post Posted 09/04/2013 07:44 PM 7.3.3. The only difference in this one and the other system is that this one is an ISDN PRI on Windows 2008 R2. The other system was a 4 line analog on Windows 7. 0904_0716_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 09/04/2013 08:06 PM Trace shows the outgoing calls loaded only had the 'live person' script specified. The 'answering machine' setting was left empty. On ISDN systems if the answering machine script is not specified then VoiceGuide will start the 'live person' script immediately when call recipient picks up the handset. (ISDN system can tell when the handset is picked up). If you want system to still wait to listen to what is said on the line after handset pickup to determine whether the call was answered by live person or by answering machine then you need to specify what script or .WAV file you would like VoiceGuide to run/play when answering machine is detected. Note that this will mean that script no longer starts as soon as handset is picked up - system will wait to hear what is said/played on line first - which is what is needed on analog lines to determine if call was answered. 080000.472 6 2 1 dial StartOutgoingCall start tel[(removed)] live[d:\payrem\water_cnp.wav] am[] fax[] onNotAnswered[] onRetriesEnd[] rv[] CampaignName[WTR_CNP:9269304-2051539] options[<CallerID>8035453000</CallerId>] ID=128461 Share this post Link to post
SupportTeam Report post Posted 09/04/2013 08:15 PM Also I can't tell which are SIT. ISDN systems do not play SIT tones. On ISDN systems calls to disconnected will usually be given a disposition of DISCONNECTED and saved in corresponding CDR log. Sometimes calls to non-existing numbers will be given disposition of NOTCONTACTED (instead of DISCONNECTED) - it depends on what ISDN level responses system receives from the remote switch/PBX in response to to outgoing call attempt. Share this post Link to post
SupportTeam Report post Posted 09/05/2013 12:23 AM Looking at one example call from provided trace, we see that an outgoing call received a DISCONNECTED message 10 seconds after dialing the number. No 'Proceeding' or 'Alerting' events were received for this call - just the 'Disconnected'. This call was given a disposition of "NOTCONTACTED". 080000.577 19 16 6 ev CallState GCEV_DIALING, crn=288000b, iEvent=2 ,16,0,16, s1:, s2:, s3:]. build_date: 2013-07-16 21:32:05.02 080010.425 19 16 6 ev CallState GCEV_DISCONNECTED, crn=288000b, iEvent=2 ,16384,0,64, s1:, s2:, s3:]. build_date: 2013-07-16 21:32:05.02 080010.426 6 16 6 state Hanging up... [LINECALLSTATE_DISCONNECTED] 080010.432 19 16 6 ev CallState GCEV_DROPCALL, crn=288000b, iEvent=2 ,1,0,32, s1:, s2:, s3:]. build_date: 2013-07-16 21:32:05.02 080010.434 6 16 6 CDR (out) : "WTR_CNP:15275008-1073542","8035453000","8032108766","","","","","","","'2013-09-04 08:00:00'","'0001-01-01 00:00:00'","'2013-09-04 08:00:10'",10,0,"NOTCONTACTED","","" => C:\Program Files (x86)\VoiceGuide\cdr\CDR_20130904_out.txt , C:\Program Files (x86)\VoiceGuide\cdr\CDR_20130904_out_NOTCONTACTED.txt Share this post Link to post
Guest u4910 Report post Posted 09/05/2013 12:54 PM Thank you very much for your detailed and quick response! I will put in the answering machine setting immediately. Share this post Link to post
Guest u4910 Report post Posted 09/06/2013 12:41 PM Thanks. Works great now. I was surprised to get a SIT. "ANSWERED" 1176 "ANSWERED_HUMAN" 25 "ANSWERED_MACHINE" 20 "ANSWERED_UNDETERMINED" 4 "NOANSWER" 283 "NOTCONTACTED" 670 "SIT" 1 Share this post Link to post
