_DZ_ Report post Posted 09/26/2013 06:46 PM I installed VoiceGuide V7 on a Win 2003 server and copied the V6 script from the old server. I added the dialogic drivers and I licensed the new card. I attached the database in windows, which exists on another server (cluster actually). The card picks up the incoming call and the script initiates, however the input from the user is never recognised and then the call is ended by the software. Ive attached the log file generated from voice guide. Im not sure where to go from here, and am wondering if there is something I should modify for the input to be regognized. 0924_CallEvents.txt Share this post Link to post
SupportTeam Report post Posted 09/26/2013 08:30 PM Can you please post the vgEngine trace file that captures the call. Please .ZIP trace files before posting them. Share this post Link to post
_DZ_ Report post Posted 09/26/2013 09:35 PM Heres the VG engine trace log, please let me know. 0924_1506_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 09/26/2013 10:19 PM Trace shows incoming call is answered and sound file D:\Program Files\VoiceGuide\Scripts\ColoradoNoCall\startup.wav is played. startup.wav completes playing after 21 second, and 10 seconds after file completes playing the timeout path to module [Hangup the Call] is taken, and the call is ended. The Dialogic card does not report any DTMF keypresses from caller during entire time of the call. We assume that script does expect some input from caller, yes? Were any keys pressed by caller during the call? Did caller try pressing any keys after the startup.wav completed playing? 151613.015 6 3 2 state [Start Call] Playing wav (startup.wav) 151613.031 6 3 2 FindSoundFile start [startup.wav] 151613.031 6 3 2 t timer clear (force=False) 151613.031 6 3 2 q tel add cmd_PlayStart 612656 ,D:\Program Files\VoiceGuide\Scripts\ColoradoNoCall\startup.wav [] 151613.031 6 3 2 play start ok, playId=612656 151613.031 7 q tel max count 1 151613.031 6 q scr max time 00:00:00.1562500 151613.031 7 q tel max time 00:00:00 151613.031 7 3 2 q tel run cmd_PlayStart 00:00:00 max:1|00:00:00 151613.031 6 3 2 q scr run evScriptEvent sCode=[TDX_CST] iActionID=0, crn=10000001[44468|0|0|0|0][DE_LCON|||||] 00:00:00.1562500 max:1|00:00:00.1562500 151613.031 6 3 2 scriptevent TDX_CST 44468|0|0 DE_LCON|| LineState=LS_PLAY_PLAYMSG 151613.031 6 3 2 LsPlayMsg EV_UNKNOWN_134,TDX_CST 151613.031 6 3 2 path {TDX_CST} not found 151632.046 17 3 2 ev PlayEnd 3 612656 151632.046 17 3 2 play end id=612656, (current id). Setting .lPlayId=0 151632.046 17 3 2 q scr add evScriptEvent 8001 EV_PLAY_FINISHED 151632.046 6 3 2 q scr run evScriptEvent sCode=[EV_PLAY_FINISHED] iActionID=0, crn=0[612656|0|0|0|0][|||||] 00:00:00 max:1|00:00:00.1562500 151632.046 6 3 2 scriptevent EV_PLAY_FINISHED 612656|0|0 || LineState=LS_PLAY_PLAYMSG 151632.046 6 3 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 151632.046 6 3 2 path {EV_PLAY_FINISHED} not found 151632.046 6 3 2 iCurrReplayCount=0, iMaxReplayCount=0 151632.062 6 3 2 t timer set 10 sec : EV_TIMEOUT_HANGUP 151632.062 6 3 2 t timer set 10 sec : EV_TIMEOUT_GOTOMODULE 151641.921 4 3 2 timer EV_TIMEOUT_GOTOMODULE 151641.921 4 3 2 q scr add evScriptEvent 9002 EV_TIMEOUT_GOTOMODULE 151641.921 6 3 2 q scr run evScriptEvent sCode=[EV_TIMEOUT_GOTOMODULE] iActionID=0, crn=0[0|0|0|0|0][|||||] 00:00:00 max:1|00:00:00.1562500 151641.921 6 3 2 scriptevent EV_TIMEOUT_GOTOMODULE 0|0|0 || LineState=LS_PLAY_PLAYMSGFINISHED 151641.921 6 3 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE, [ ], [ ], [] 151641.921 6 3 2 path {EV_TIMEOUT_GOTOMODULE} not found 151641.921 6 3 2 FindNextVgmTitleInPathList: next module title is=[Hangup the Call] 151641.921 6 3 2 t timer clear (force=False) 151641.921 6 3 2 RunModule start Hangup the Call, [Hangup the Call], iModuleIdx=11, previous: vgm=1, vgs=1:1 151641.937 6 3 2 HangupCall, source=Hangup Module, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0 151641.953 6 3 2 moduleTitle=[Hangup the Call] 151641.953 6 3 2 ScriptWorkingMode set Stopping, (called from HangupCall) 151641.953 6 3 2 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL) 151641.953 6 3 2 state Hanging up... [Hangup Module] Share this post Link to post
SupportTeam Report post Posted 09/26/2013 10:32 PM To check whether the Dialogic card is hearing the DTMF tones a record module can be used to record what is happening on the line. When the record module is recording, have the caller press a few keys on the telephone keypad. End call by just hanging up, or hanging up the call in Line Status Monitor. Then post the recording made and the vgEngine trace. (all .ZIPed). We can then see what is heard by Dialogic card and whether the Dialogic card is reporting the tones. Share this post Link to post
_DZ_ Report post Posted 09/26/2013 10:34 PM Yes, it asks to press 1 to continue. 1 was pressed. After that it asks for a valid area code, and at that point 303 was pressed. Share this post Link to post
SupportTeam Report post Posted 09/26/2013 10:55 PM When the record module is recording, have the caller press a few keys on the telephone keypad. The caller can say which button they are pressing right before they are pressing it. this way we can confirm that voice path itself is established. Share this post Link to post
_DZ_ Report post Posted 09/27/2013 04:01 PM I opened up the sound recording application, but it will not work as there is no sound device installed. The previous server doesnt have one either. It's questionable as to whether a sound card can be installed in this 1U rack server. Is there another way of testing this? Share this post Link to post
SupportTeam Report post Posted 09/27/2013 09:19 PM Using a VoiceGuide record module as part of the VoiceGuide script does not require any type of "sound recording application" to be installed on the system. To preform a recording of what is happening on the line just use a Record module. Make it the start module of the script. Then call the system and the record module will record what is said/pressed on the line. See: http://www.voiceguide.com/vghelp/source/html/modrecord.htm Then post both the recording and the vgEngine trace capturing the call. Share this post Link to post
_DZ_ Report post Posted 09/28/2013 09:27 PM I replaced the normal script we had been using with the default "Answer and Record" script path (provided by the voiceguide program) in the config.xml file. I then rebooted, as the call would not be picked up after just restarting the service. The call was answered and buttons were pressed while speaking the numbers, however the call was then hungup by the program before the number two was reached. Answer&Record.zip Share this post Link to post
SupportTeam Report post Posted 09/28/2013 11:07 PM The recording of the call was not posted. Trace shows that the recording was made in file: D:\Program Files\VoiceGuide\Scripts\Pickup Line And Record\__0928_151221.wav Trace also shows that Dialogic card stopped recording as it could not hear anything on the line - so recording was ended due to silence being longer then the "maximum silence timeout" setting (default is 3 seconds on this system). So that recording most likely contains just silence - but it would be worth to see the recording as well. So it looks like there is a problem with the telephone connection this system, or with the card itself. To test the line: take the line plugged into the Dialogic card and plug it into a normal analog telephone, then call it. Can the two parties hear each other? 151221.468 6 3 2 state [Record Coversation] Recording D:\Program Files\VoiceGuide\Scripts\Pickup Line And Record\__0928_151221.wav 151221.484 6 3 2 q tel add cmd_SilenceDetectSet [30,10,0,0,0][||||] 151221.484 7 3 2 q tel run cmd_SilenceDetectSet 00:00:00 max:4|00:00:00.4375000 151221.484 6 3 2 q tel add cmd_RecordFileStart 339109 D:\Program Files\VoiceGuide\Scripts\Pickup Line And Record\__0928_151221.wav [] 151221.484 6 3 2 RecSoundStart [D:\Program Files\VoiceGuide\Scripts\Pickup Line And Record\__0928_151221.wav] ok 151221.484 7 3 2 q tel run cmd_RecordFileStart 00:00:00 max:4|00:00:00.4375000 151221.484 6 3 2 t timer set 3600 sec : EV_TIMEOUT_RECMAXTIME 151221.484 6 3 2 q scr run evScriptEvent sCode=[TDX_CST] iActionID=0, crn=10000001[25951|0|0|0|0][DE_LCON|||||] 00:00:00.0156250 max:6|00:00:00.1093750 151221.484 6 3 2 scriptevent TDX_CST 25951|0|0 DE_LCON|| LineState=LS_REC_RECORDING 151221.484 6 3 2 LsRecRecording EV_UNKNOWN_134,TDX_CST 25951|0|0 DE_LCON|| 151221.484 6 3 2 path {TDX_CST} not found 151224.546 16 3 2 ev Silence 151224.546 16 3 2 q scr add evScriptEvent 9300 EV_SILENCE_DETECTED 151224.546 16 3 2 ev Dialogic 130,TDX_RECORD, crn=10000001, 0,0,0,TM_MAXSIL,, Share this post Link to post
_DZ_ Report post Posted 10/04/2013 01:29 AM You were correct in explaining that it looked like there was a telephony issue. I was able to correct that upstream of the server and replace the original scriprt in the config.xml file. The call comes in and the user input is accepted, however somehow the input fails when attempting to write it into the database on the cluster. What it says is that the operation failed; and this is in the custom recorded voice so I know it is part of the script. Do you think that the connection to the database is correct and that the database is being read? Alternately, do you think that the error is in writing to the database? 1003_1706_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 10/07/2013 12:22 PM Trace shows: 171315.265 6 3 2 state [Database Query 1] DB Query 171315.265 6 3 2 rv replace start [select * from Consumer where phonenumber='$RV[Get Area Code]$RV[Get Phone]' AND zipcode=$RV[Get Zip Code]] 171315.265 6 3 2 rv replace end [select * from Consumer where phonenumber='3038172949' AND zipcode=80501] 171315.265 6 3 2 db strDatabaseName=[SQL3] strDbConnectString=[ODBC;DSN=SQL3;UID=NCBasic;PWD=0p3nsc4n12!;] sAdoNetFactoriesAvailable=[|System.Data.Odbc|System.Data.OleDb|System.Data.OracleClient|System.Data.SqlClient|System.Data.SQLite|Npgsql|] 171315.265 6 3 2 db did not find ado.net data provider : SQL3 171315.265 6 3 2 db PlayOnHoldFile 171315.265 6 3 2 moh file not specified 171315.265 6 3 2 db using ado.net ODBC data provider : OdbcConnection/OdbcCommand/etc 171315.265 6 3 2 db odbc RunQuery_Odbc [Database Query 1], db=[], connect=[DSN=SQL3;UID=NCBasic;PWD=0p3nsc4n12!;], sql=[select * from Consumer where phonenumber='3038172949' AND zipcode=80501] 171315.265 6 3 2 odbc DSN not specified, using a DSN-less ODBC connection. 171315.265 6 3 2 db odbc thread init (threadpool) 171315.265 6 3 2 db odbc thread started (threadpool) 171315.265 6 3 2 t timer set 5 sec : EV_TIMEOUT_GOTOMODULE 171315.265 17 3 2 ev PlayEnd 3 465000 171315.265 17 3 2 play end id=465000, (current id). Setting .lPlayId=0 171315.265 17 3 2 q scr add evScriptEvent 8001 EV_PLAY_FINISHED 171315.265 6 3 2 q scr run evScriptEvent sCode=[EV_PLAY_FINISHED] iActionID=0, crn=0[465000|0|0|0|0][|||||] 00:00:00 max:1|00:00:00.0156250 171315.265 6 3 2 scriptevent EV_PLAY_FINISHED 465000|0|0 || LineState=LS_DBQUERY 171315.281 6 3 2 LsDbQuery EV_PLAY_FINISHED,EV_PLAY_FINISHED 171315.281 6 3 2 play end id=465000, iRunWait_MohPlayWasStarted=0. ignoring 171315.281 13 3 2 db odbc connection create call. 171315.312 13 3 2 db odbc connection open call. 171315.390 13 3 2 ERROR v0.0.0.0 (2013-05-02 23:45:07.90) ConnectAndRun_Odbc init : ERROR [IM002] [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified So looks like the ODBC Data Source is not defined. If you still encounter issues with the database access please start a new thread on that new topic. Share this post Link to post
SupportTeam Report post Posted 10/07/2013 12:25 PM Try changing DSN=SQL3 to: DBQ=SQL3 If you still encounter issues with the database access please start a new thread on that new topic. Share this post Link to post
