invoso.com Report post Posted 10/16/2013 09:44 AM Hi, in my project I Use sometimes VBS like: set vg = CreateObject("vgServices.CommandLink")vg.Play_Start $RV_LINEID, "moh.wav"vg.Run_ResultReturn $RV_LINEID, "success"set vg = Nothing Do not wait for VB script to complete. and when I need to stop MOH I use set vg = CreateObject("vgServices.CommandLink")vg.Play_Stop $RV_LINEIDset vg = NothingRem STOP MoH to connect with waiting until script completes. Stopping vg.Play need 1-1,5 second to execute. Problem is when before no MoH declared and this 1-2 seconds is additional silence period. Solution? 1. How to detect running vg.play to eliminate unnecessary use of vg.play_stop task? 2. can You to change VG to stop current play task (for example: moh) when play module or other play elements (On-Hold sonud in transfer module) is used? Some time ago it was available but no longer. Share this post Link to post
SupportTeam Report post Posted 10/16/2013 07:56 PM Stopping play is immediate. The delay in second script would be that no "vg.Run_ResultReturn" was issued, and the module checks for result file and whether that module's script is still running only once every second. If you add vg.Run_ResultReturn then that module will return without this pause. Share this post Link to post
invoso.com Report post Posted 10/17/2013 07:08 AM Hi, What exactly I should to add to achieve suspected effect? vg.Run_ResultReturn $RV_LINEID, "success" or vg.Run_ResultReturn each has no suspected result and now process need up to 5 seconds. 085826.547 3 28 10 state [sTOP MoH to connect_130] type: Script_VBScript, iRunWait=1085826.547 3 28 10 rv replace start------------------------------set vg = CreateObject("vgServices.CommandLink")vg.Play_Stop $RV_LINEIDset vg = Nothingvg.Run_ResultReturn $RV_LINEID, "success"Rem STOP MoH to connect------------------------------085826.547 3 28 10 rv replace end [set vg = CreateObject("vgServices.CommandLink")vg.Play_Stop 28set vg = Nothingvg.Run_ResultReturn 28, "success"Rem STOP MoH to connect]085826.547 3 28 10 script will be ran from file: C:\Program Files (x86)\VoiceGuide\temp\vbs_28_1.vbs085826.547 3 28 10 on hold file: , iModuleIdx=1214085826.547 3 28 10 delete existing: C:\Program Files (x86)\VoiceGuide\temp\vbs_28_1.vbs085826.548 3 28 10 current objVbsOrExeProcess=085826.548 3 28 10 RunVBScriptFile [wscript][C:\Program Files (x86)\VoiceGuide\temp\vbs_28_1.vbs][] timeout=5 (vbsPath=C:\Program Files (x86)\VoiceGuide\temp), start (new Process)085826.548 3 28 10 objVbsOrExeProcess.Start call085826.559 3 28 10 RunVBScriptFile just started. Handle=20368, Id=8120, StartTime=2013-10-17 08:58:26, HasExited=False085826.560 3 28 10 VBScript started [C:\Program Files (x86)\VoiceGuide\temp\vbs_28_1.vbs], ProcessHandle=[20368], VbsOrExeProcess.WorkingSet=[679936]085826.560 3 28 10 RunModule_Script_AfterScriptStarted start085826.560 3 28 10 Run Script waiting. iRunWait=1 (process:20368)085826.560 3 28 10 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE085826.560 3 28 10 moh file not specified ... 085830.688 6 28 10 LsRunWaitTillFinished: process still running085830.688 6 28 10 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE085831.731 29 28 10 timer EV_TIMEOUT_CHECKONSTATE085831.731 29 28 10 q scr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE085831.731 6 28 10 q scr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||] 00:00:00 max:6|00:00:00.7430425085831.731 6 28 10 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 || LineState=LS_RUN_WAITTILLFINISHED085831.731 6 28 10 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE085831.731 6 28 10 Process.HasExited is false (awaiting process end or COM function call) handle=20368, id=8120, StartTime=2013-10-17 08:58:26085831.731 6 28 10 .ExitTime returned error.085831.731 6 28 10 LsRunWaitTillFinished: process still running085831.731 6 28 10 t timer set 1 sec : EV_TIMEOUT_CHECKONSTATE085832.776 29 28 10 timer EV_TIMEOUT_CHECKONSTATE085832.776 29 28 10 q scr add evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE085832.776 6 28 10 q scr run evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0[0|0|0|0|0][|||||] 00:00:00 max:6|00:00:00.7430425085832.776 6 28 10 scriptevent EV_TIMEOUT_CHECKONSTATE 0|0|0 || LineState=LS_RUN_WAITTILLFINISHED085832.776 6 28 10 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE085832.776 6 28 10 Process.HasExited is false (awaiting process end or COM function call) handle=20368, id=8120, StartTime=2013-10-17 08:58:26085832.776 6 28 10 .ExitTime returned error.085832.776 6 28 10 LsRunWaitTillFinished: process still running085832.776 6 28 10 objVbsOrExeProcess.Kill (timeout) (System.Diagnostics.Process (wscript))085832.776 6 28 10 FindNextVgmTitleInPathList: next module title is=[czy SMS screening] Share this post Link to post
SupportTeam Report post Posted 10/17/2013 09:43 AM In the VBScript module you are calling: set vg = Nothing before: vg.Run_ResultReturn $RV_LINEID, "success" Setting object to 'Nothing' and then using it afterwards is an error. Share this post Link to post
invoso.com Report post Posted 10/17/2013 11:37 AM still 1 second duration 133426.092 13 7 3 state [sTOP MoH to connect last] type: Script_VBScript, iRunWait=1133426.092 13 7 3 rv replace start------------------------------set vg = CreateObject("vgServices.CommandLink")vg.Play_Stop $RV_LINEIDvg.Run_ResultReturn $RV_LINEID, "success"set vg = Nothing------------------------------133426.092 13 7 3 rv replace end [set vg = CreateObject("vgServices.CommandLink")vg.Play_Stop 7vg.Run_ResultReturn 7, "success"set vg = Nothing] ... 133427.173 6 7 3 FindNextVgmTitleInPathList: next module title is=[update polaczenia telefony first rch] Share this post Link to post
SupportTeam Report post Posted 10/17/2013 12:41 PM Looks like the system is running on a lower-spec hardware. It should not take over half a second to start the running of a VBScript. Have you looked at CPU usage on this system? Is any anti-virus software running on this system? Share this post Link to post
invoso.com Report post Posted 10/17/2013 01:36 PM CPU i5-3470 3.20 GHz 4 Core CPU usage no more than 30 % (simple core) Share this post Link to post
SupportTeam Report post Posted 10/17/2013 09:09 PM Is there anything else running on this system apart from Windows + Dialogic drivers+ VoiceGuide ? Any anti-virus software or other software that could interfere with normal running of external scripts and applications? Is the 30% usage coming from other channels handling calls on this system? How many lines is this system handling? Do you mean that one of the cores is showing 30% and others are close to 0, or is the average across the 4 cores 30% ? Can you advise full system specs. esp. version Windows used on this system and how much RAM does the system have? Share this post Link to post
SupportTeam Report post Posted 10/23/2013 12:27 AM In the just released v7.4.0 the the Play_Stop signal can also be issued from the Evaluate Expression module. Just specify: Play_Stop as the expression to be evaluated and the play stop command will be issued. This should allow you to issue Play_Stop commands without needing to resort to using especially created VBScripts. v7.4.0 can be downloaded here: [old link removed] To upgrade: stop VG service, then run installer and install over the top of existing install. Share this post Link to post
invoso.com Report post Posted 10/23/2013 07:47 AM Can You describe changes include VG 7.4.0 comparing to previous 7.3.3_130613 version? Is any list of features added to VG as solutions suggested in this forum? Share this post Link to post
SupportTeam Report post Posted 10/23/2013 08:35 AM There were no major features added since 7.3.3_130613. v7.4.0 has a rewrite of lower level ISDN signalling handlers. This was made to handle glare conditions without raising any errors. (Glare conditions occasionally happen on ISDN systems when incoming and outgoing calls are made on same channel at the same time.) Share this post Link to post
