Speak Numbers Problem
Crash in Speak numbers module.. I am trying to get it to say 0,1,2,3,4,5,6,7,8,9
but when it gets to number 1 it trys to take the sound file from somewhere it shuold not and crashes the call....
How can i make sure the numbers are all taken from the specified directory?
C:\Program Files\VoiceGuide\System\voice_1001\
c:\program files\voiceguide\scripts\distributors\Call-Admin\Example-Recording.wav,0.wav,1.wav,2.wav,3.wav,4.wav,5.wav,6.wav,7.wav,8.wav,9.wav
095955.88 11 PlaySoundStart ok
C:\Program Files\VoiceGuide\System\voice_1001\0.wav,
c:\program files\voiceguide\scripts\distributors\Call-Admin\1.wav,
C:\Program Files\VoiceGuide\System\voice_1001\2.wav,
C:\Program Files\VoiceGuide\System\voice_1001\3.wav,
C:\Program Files\VoiceGuide\System\voice_1001\4.wav,
C:\Program Files\VoiceGuide\System\voice_1001\5.wav,
C:\Program Files\VoiceGuide\System\voice_1001\6.wav,
C:\Program Files\VoiceGuide\System\voice_1001\7.wav,
C:\Program Files\VoiceGuide\System\voice_1001\8.wav,
C:\Program Files\VoiceGuide\System\voice_1001\9.wav]
From VG Help file:
To select a different set of system files to be used for the current call, the path pointing to the new system directory current for this call needs to be written to the $RV[DIRSYSTEMVOICE] Result Variable.
Please see the Multilanguage Systems part of the Help file.
Which version of VG are you using?
Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
My voice guide version is 5.1.3310
As you can see i have already altered the SYSTEM Voicefiles but when it wants 1.wav it trys to get it from a different place for some reason..
140736.76 11 [set Sounds_1] Evaluate ["C:\Program Files\VoiceGuide\System\voice_$RV"]
140736.78 11 RVreplace start: ["C:\Program Files\VoiceGuide\System\voice_$RV"]
140736.81 11 RVreplace end: ["C:\Program Files\VoiceGuide\System\voice_1001"]
140736.83 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_1001"))
140736.86 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_1001] stored in $RV[DIRSYSTEMVOICE]
140736.88 11 path {C:\Program Files\VoiceGuide\System\voice_1001} not found
140736.90 11 [Replay Phone Number] Say numbers: 0123456789 as Digits
140736.93 11 fn PlaySoundStartNumbers Example-Recording.wav, , 0123456789, Digits
140736.95 11 sVbsFunctionToUse=Digits
140737.08 11 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_11_SayNumber.vbs)
140737.15 11 cl Play_Start c:\program files\voiceguide\scripts\distributors\Call-Admin\Example-Recording.wav,0.wav,1.wav,2.wav,3.wav,4.wav,5.wav,6.wav,7.wav,8.wav,9.wav
140737.79 11 PlaySoundStart ok [c:\program files\voiceguide\scripts\distributors\Call-Admin\Example-Recording.wav,C:\Program Files\VoiceGuide\System\voice_1001\0.wav,c:\program files\voiceguide\scripts\distributors\Call-Admin\1.wav,C:\Program Files\VoiceGuide\System\voice_1001\2.wav,C:\Program Files\VoiceGuide\System\voice_1001\3.wav,C:\Program Files\VoiceGuide\System\voice_1001\4.wav,C:\Program Files\VoiceGuide\System\voice_1001\5.wav,C:\Program Files\VoiceGuide\System\voice_1001\6.wav,C:\Program Files\VoiceGuide\System\voice_1001\7.wav,C:\Program Files\VoiceGuide\System\voice_1001\8.wav,C:\Program Files\VoiceGuide\System\voice_1001\9.wav]
140758.49 11 callstate DISCONNECTED 65844,0,0
140758.52 11 LsSayNbrPlay EV_REMOTEPARTY_DISCONNECT
140758.54 11 Hanging up call...
140758.56 11 RecSoundStop ok
140758.63 11 PlaySoundStop ok
140758.66 11 fnHangupCall end
140758.70 11 linedevstate 2048 0 0
140758.77 11 callstate IDLE 65844 0 0
140758.79 11 WorkingMode@Idle=
140758.98 11 tapi Reply (LineEvReply) ok 65639 0
140759.89 11 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
140759.91 11 ReinitTelephony due to IDLE start
140759.95 11 tapic lineDeallocateCall(MainCall:65844) 0
140800.18 11 lineOpen(11) => 0
140800.20 11 Waiting for a call...
140800.23 11 lineOpen(11)LineHandle=65622
The trace shows that VG attempts to play the files from the directory "C:\Program Files\VoiceGuide\System\voice_1001\" - that is what this line in the trace is showing:
It looks like this is the directory which you wanted to set:
The trace also show that about 20 seconds after starting playing the files VG was informed that there is a busy tone on the line:
If you this busy tone is detected falsely then you should take a look at how the disconnect tone frequencies/cadence & their variances are set up to ensure that the false detection possibility is reduced. You may also want to look into re-recording the sound files during which the false busy detection is occurring.
