vgnewb1 Report post Posted 11/14/2013 10:41 PM My goal is to measure call length from the time of voice detection until hangup. Currently, VG measures call length from time of dialing until hangup. Is a RV available to measure the particular interval of the call? Other ideas? Running 2 machines, one with v6 and the other with v7. Thanks. Share this post Link to post
SupportTeam Report post Posted 11/14/2013 11:16 PM This questions relates to outgoing calls, correct? The VoiceGuide v7 CDR logs include the following fields: 10 : start: Start of call (date/time) 11 : answer: Answer of call (date/time) 12: hangup: End of call (date/time) 13 : duration: Total time in system, in seconds (integer) 14 : billsec: Total time call is up, in seconds (integer) Please see: http://www.voiceguide.com/vghelp/source/html/log_cdrs.htm Field 14 holds the billable time value. Are you using ISDN trunks? ISDN will provide precise timing of call answer - whereas Analog relied on voice detection to determine call answer. (VoIP will usually provide precise timing of call answer as well) If you want to use $RV_CALLLENGTH to check for 'billable time' while still running the script then you can just save value of $RV_CALLLENGTH at beginning of script and then to get billable time at any time later in the script just subtract the saved value from the current value of $RV_CALLLENGTH. Please let us know if you have any other questions, Share this post Link to post
