invoso.com Report post Posted 11/20/2013 09:39 AM I use timeout parameter to disconnect prepaid connection. I use: 112810.979 6 55 19 RunModule start Evaluate, [warning 30 sekund], iModuleIdx=726, previous: vgm=664, vgs=14:14112810.979 6 55 19 state [warning 30 sekund] Evaluate [$RV[max_con_time]-30]112810.979 6 55 19 rv replace start [$RV[max_con_time]-30]112810.979 6 55 19 rv replace end [818-30]112810.979 6 55 19 eval [818-30]112810.979 6 55 19 eval InvokeMember Eval returned112810.979 6 55 19 rvns add warning 30 sekund_Input|818-30112810.979 6 55 19 rvns add warning 30 sekund|788112810.979 6 55 19 creating new (non-global) rv : warning before end112810.979 6 55 19 rvns add warning before end|788112810.980 6 55 19 Eval Expr result:[788] stored in RV[warning before end] to warn caller 30 seconds before disconnection i use warning before end to set timeout in "just wait" module. 112810.980 6 55 19 state [just wait] Playing wav ()112810.980 6 55 19 q_scr + evScriptEvent 8001 EV_PLAY_FINISHED112810.981 6 55 19 q_scr run evScriptEvent sCode=[EV_PLAY_FINISHED] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00 max:12|00:00:02.0711185112810.981 6 55 19 se EV_PLAY_FINISHED 8001 0|0|0 || LineState=LS_PLAY_PLAYMSG112810.981 6 55 19 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED112810.981 6 55 19 rv replace start------------------------------on {timeout $RV[warning before end]} goto [play warning]------------------------------112810.981 6 55 19 rv replace end [on {timeout 788} goto [play warning]]112810.981 6 55 19 path {EV_PLAY_FINISHED} not found112810.981 6 55 19 iCurrReplayCount=0, iMaxReplayCount=0112810.981 6 55 19 t timer set 10 sec : EV_TIMEOUT_HANGUP112810.981 6 55 19 rv replace start [ $RV[warning before end]]112810.981 6 55 19 rv replace end [ 788]112810.981 6 55 19 t timer set 788 sec : EV_TIMEOUT_GOTOMODULE just wait module start at 11:28:10 so + 788 seconds should to start play warning at 11:41:18 but: 114150.927 6 55 19 q_scr run evScriptEvent sCode=[EV_TIMEOUT_GOTOMODULE] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00.7890451 max:12|00:00:02.5111437114150.927 6 55 19 se EV_TIMEOUT_GOTOMODULE 9002 0|0|0 || LineState=LS_PLAY_PLAYMSGFINISHED114150.927 6 55 19 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE, [ ], [ ], []114150.927 6 55 19 rv replace start------------------------------on {timeout $RV[warning before end]} goto [play warning]------------------------------114150.927 6 55 19 rv replace end [on {timeout 788} goto [play warning]]114150.927 6 55 19 path {EV_TIMEOUT_GOTOMODULE} not found114150.927 6 55 19 FindNextVgmTitleInPathList: next module title is=[play warning] 114150.928 6 55 19 t timer clear (force=False)114150.928 6 55 19 RunModule start Play, [play warning], iModuleIdx=731, previous: vgm=730, vgs=14:14114150.928 6 55 19 [play warning] VGMTYPE_PLAY run start114150.928 6 55 19 CheckForAnyPlayActionsAndSetkeysIfNecessary no PlayActions, vgmidx=731, strPaths=on {timeout 26} goto [Hangup the Call 1] why VG follow to nex module at 11:41:50 not at 11:41:18? but next timeout working properly (timeout 26 after 4 seconds long warning prompt make 30 seconds) : 114220.295 6 55 19 q_scr run evScriptEvent sCode=[EV_TIMEOUT_GOTOMODULE] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00.2680154 max:12|00:00:02.5111437114220.295 6 55 19 se EV_TIMEOUT_GOTOMODULE 9002 0|0|0 || LineState=LS_PLAY_PLAYMSGFINISHED114220.295 6 55 19 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE, [ ], [ ], []114220.295 6 55 19 path {EV_TIMEOUT_GOTOMODULE} not found114220.295 6 55 19 FindNextVgmTitleInPathList: next module title is=[Hangup the Call 1]114220.295 6 55 19 t timer clear (force=False)114220.295 6 55 19 RunModule start Hangup the Call, [Hangup the Call 1], iModuleIdx=860, previous: vgm=731, vgs=14:14114220.295 6 55 19 HangupCall (Hangup Module) crn_in=0, L1=Connected, L2=Running_Normal, lPlayId=0, lRecId=0114220.295 6 55 19 ccrn_connected=2e40265, crn_NewIncomingCall=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=0114220.295 6 55 19 rv add Hangup Source|Hangup Module Share this post Link to post
SupportTeam Report post Posted 11/20/2013 11:31 AM (edited) Looks like there is something happening on your system which makes the timers drift considerably - and it becomes noticeable on longer time intervals. This version of VG should resolve the issue (it will detect timers drifting and adjust accordingly): [old link removed] If you continue to have problems please post full vgEngine trace from this new version - not just excerpts - and quote the timestamps and ports that we should be looking at. Edited 07/27/2017 12:24 AM by SupportTeam link updated Share this post Link to post
