kaangyib Report post Posted 12/02/2013 04:16 AM Dear support team, How can I set Dialogic card or from VoiceGuide to disbale CRC check? We have disbale the CRC check in the PBX system but all my 30 channels line will auto refresh after 30 minutes or more. I can determine this by looking at VGLineStatus by putting some channel in maintenance mode and after 30 minutes or more, it changed to "wating for calls" mode automatically. Please advise. Share this post Link to post
SupportTeam Report post Posted 12/02/2013 05:08 AM Can you please advise which Dialogic card you are using and what is the connection protocol used by the card? Share this post Link to post
kaangyib Report post Posted 12/02/2013 05:57 AM I'm using D300JCT with a CT bus connector connecting to D120JCT. E1 line terminated at D300JCT and no physical connection from PBX to D120JCT. Share this post Link to post
kaangyib Report post Posted 12/02/2013 05:58 AM I forget to mentioned, I'm using QTE protocol for the D300JCT. Share this post Link to post
SupportTeam Report post Posted 12/02/2013 07:47 AM On JCT cards the CRC can be set in the SPANDTI.PRM file or in the .PRM file used for your ISDN protocol.. CRC ENABLE SWITCH is parameter type 0FH 000F 00 ; turn CRC off (default) 000F 01 ; turn CRC on If you have any issues with configuring the card and connecting with it to the PBX/Switch then please contact the card supplier. Share this post Link to post
kaangyib Report post Posted 12/02/2013 08:40 AM Hi, Can I know where to find SPANDTI.PRM or .PRM files? I do a search in my local drive and couldn't locate the file. Thanks! Share this post Link to post
SupportTeam Report post Posted 12/02/2013 07:53 PM On Windows 7, Windows 2008, Windows 2012 systems the PRM and CONFIG files are located in this directory: C:\ProgramData\Dialogic\data\ The C:\ProgramData\ directory is a hidden directory, and needs to be made visible first. To make C:\ProgramData\ directory visible click on C:\ drive in Windows Explorer, then click on the "Organize" button in top left corner and select "Folder and Search Options". Click on "View" tab and select "Show hidden files, folders and drives" option. Share this post Link to post
