How To Transfer An Incoming Fax?
Hi there!
I have a question for you...
I need to detect an incoming fax signal and transfer the call to another line (fax line). Is it possible?
Thank u very much!
Ale
Yes, it is.
In the first module have a path:
on {fax} goto [Transfer Call]
where the Transfer Call points to the call transfer module which transfers the call to the fax machine's extension.
Then when the fax calling tone is detected the "on {fax} goto ..." path will be taken.
Thanks a lot for your reply, I tried but it didn't work...
Reading the trace i can see that VoiceGuide detect an incoming call, but not as fax. First module don't transfer the call, but it waits until it goes on timeout.
I don't know why... I am working on VG 5.1.7 version.
Maybe I forgot something...
Can you help me?
Thank you
Ale
If the calling fax is sending the fax 'beep' tones then the modem/Dialogic should have detected those...
Are you using a modem or a Dialogic card?
Could you please post a copy of VoiceGuide's Debug Printout which captures the incoming fax call, this will allow us to see what is going wrong.
Hi there!
Here is the request trace log...
002707.18 0 sys cleanup Start
002707.19 0 sys cleanup End
002726.81 0 callstate OFFERING 65582 0 4
002726.81 0 Answer the call at 1/29/2004 12:27:26 AM
002726.81 0 lineAnswer(65582) => 65855
002726.82 0 ring 1
002726.82 0 callstate ACCEPTED 65582 0 0
002726.89 0 tapi Reply (LineEvReply) ok 65855 0
002726.93 0 callstate CONNECTED 65582,0,0
002726.94 0 WorkingModeTAPI@Connected=
002726.95 0 WorkingModeScript@Connected=
002726.95 0 Inband detection not enabled
002726.96 0 StartLoadedVgs at 1/29/2004 12:27:26 AM
002726.98 0 [Answer] Playing
002726.98 0 [Answer] Playing ()
002726.99 0 LsPlayMsg EV_PLAY_FINISHED
002727.00 0 RunModule PLAY end
002757.05 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
002757.06 0 [Play] Playing
002757.07 0 [Play] Playing ()
002757.08 0 LsPlayMsg EV_PLAY_FINISHED
002757.10 0 RunModule PLAY end
002802.15 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
002802.17 0 [Play] Playing ()
002802.18 0 LsPlayMsg EV_PLAY_FINISHED
002807.22 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
002807.23 0 [Play] Playing ()
002807.25 0 LsPlayMsg EV_PLAY_FINISHED
002826.27 0 callstate DISCONNECTED 65582,32,0
002826.29 0 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
002826.31 0 Hanging up call...
002826.32 0 RecSoundStop ok
002826.34 0 PlaySoundStop ok
002826.35 0 fnHangupCall end
002826.68 0 callstate IDLE 65582 0 0
002826.70 0 WorkingMode@Idle=
002826.73 0 tapi Reply (LineEvReply) ok 66317 0
002827.66 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
002827.67 0 ReinitTelephony due to IDLE start
002827.69 0 tapic lineDeallocateCall(MainCall:65582) 0
002828.08 0 lineOpen(0) => 0
002828.09 0 Waiting for a call...
002828.10 0 lineOpen(0)LineHandle=66043
I am not using a Dialogic, but standard modem/fax/voice v.92
Thank you.
Ale
Looks like the modem used just does not detect the fax calling tone...
Here is a trace on our test system using v5.1.7 of VG. Test system uses a Dialogic D/4PCI card - which is what you'd want to be using anyway if you want to be able to transfer the call...
As you can see the fax calling tone is detected by Dialogic on line:
230135.58 8 monitormedia 32( G3FAX)
The presence of the "on {fax}" path is confirmed:
230135.58 8 Fax tone detected, see if current module has "on {fax}" path specifed...
230135.59 8 "on {fax}" path found
and soon after the script jumps to the Call Transfer module:
230136.03 8 [Transfer to Fax Ext] Blind Transfer to 111 (TAPI)
230131.42  8 linedevstate 2048 0 0
230131.42  8 callstate OFFERING 65588 0 4
230131.44  8 Start without answering the call
230131.44  8 StartLoadedVgs at 29/01/2004 11:01:31 PM
230131.47  8 TimeoutClear
230131.47  8 [Play 1] Playing
230131.50  8 lineAnswer(65588) => 65878
230131.50  8 Lev_CallerID [0293562591,]
230131.52  8 Lev_CallerID [0293562591,]
230131.52  8 callinfo CALLEDID
230131.52  8 callinfo ORIGIN
230131.52  8 ring 0
230132.05  8 callstate CONNECTED 65588,1,0
230132.05  8 WorkingModeTAPI@Connected=
230132.05  8 WorkingModeScript@Connected=BeforeAnswerRun
230132.08  8 Inband detection not enabled
230132.08  8 tapi  Reply (LineEvReply) ok 65878 0
230132.09  8 callinfo MONITORMODES
230132.09  8 TimeoutClear
230132.09  8 [Play 1] Playing
230132.09  8 [Play 1] Playing ()
230132.09  8 ScriptEventCode 8001 iLineState=1100
230132.09  8 LsPlayMsg EV_PLAY_FINISHED
230132.11  8 TimeoutSet 10 EV_TIMEOUT_REPLAYMSG
230132.11  8 RunModule PLAY end
230135.59  8 TimeoutClear
230135.59  8 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
230136.03  8 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
230136.03  8 ScriptEventCode 9012 iLineState=1900
230136.03  8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
230136.03  8 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
230136.06  8 lineBlindTransfer(65588,111,0) in LsXferStart => 65554
230137.63  8 callstate ONHOLDPENDTRANSFER 65588 0 0
230138.34  8 linedevstate 2048 0 0
230138.34  8 callstate IDLE 65588 0 0
230138.34  8 WorkingMode@Idle=BlindTransfer
230138.34  8 TimeoutClear
230138.38  8 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
230138.39  8 tapi  Reply (LineEvReply) ok 65554 0
230139.38  8 Timer fired EV_TIMEOUT_TIMETOREINITLINE
230139.38  8 ScriptEventCode 9008 iLineState=1900
230139.38  8 LsXferStart EV_TIMEOUT_TIMETOREINITLINE
230139.38  8 ReinitTelephony due to IDLE start
230139.39  8 tapic lineDeallocateCall(MainCall:65588) 0
230139.70  8 lineOpen(8) => 0
230139.70  8 Waiting for a call...
Hi again!
We are still trying to transfer an incoming fax call...
Now we have a Dialogic D/4PCI card...
Reading last trace I saw that it recognize fax call and tries to transfer call to an internal number... but it can't.
Can you help me?
Thank u!
Ale
VGSandTrace.zip
Are you using v5.1.7 of VG?
Are you using Dialogic SR5.1.1 drivers?
Can yuo try setting the TransferControl_TelBoards in VG.INI to TAPI and try the transfer again.
100542.86  8 [benvenuto] Number Input
100542.86  8 [benvenuto] Playing (C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav)
100542.95  8 PlaySoundStart ok [C:\VigileElettronico\VoiceGuide\Voci\MessaggioDiBenvenuto.wav]
100547.71  8 monitormedia 32( G3FAX)
100547.71  8 Fax tone detected, see if current module has "on {fax}" path specifed...
100547.72  8 "on {fax}" path found
100548.07  8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
100548.07  8 [TransFax] Blind Transfer to 2760 (Generate)
100548.08  8 tapic lineGenerateDigits(66206,!,,0) => LINEERR_RESOURCEUNAVAIL [8000004B]
100548.08  8 Hanging up call... [lineGenerateDigits ret=-2147483573]
We are using VG in version 5.1.3001,
and yes, Dialogic drivers are 5.1.1.
If we should overwrite our old version with the newer 5.1.7, our parameters will be right configured?
It's important for us because we had many problems about this project (reported in this forum like "Problem With Transfer , D/4PCI in Italy", posted by Cechov.)
Thanks a lot!
Ale
Please uninstall v5.1.3, then install v5.1.7 in a new directory - or delete the entire v5.1.3 directory after uninstalling if you wish to install VG in same directory again.
I see that the forum thread titled "Problem With Transfer , D/4PCI in Italy" which was regarding setting of correct hookflash length was resolved OK
http://voiceguide.com/forums/index.php?showtopic=989
In your opinion it's a VG version problem or a settings configuration problem (TAPI)?
I am asking this because it's a hard work for us to change version in environment production.
Thanks a lot.
Ale
I'd first try to change the call transfer control mode settings from Generate to TAPI and see if this makes a difference, and if it doesn't then I'd install v5.1.7
