No Audible Voice Over Phone Line
I bought a Dialogic D/41H which seems to test fine according to the dialogic software tests. I have been able to set up VG to recieve and dial, but I can't hear anything when dialing in or when VG dials out. I do hear the script message on the computer speakers, but nothing over the phone line. Any ideas?
Sounds like the cards Wave drivers were not correctly installed - can you
try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first. Try calling in after doing this, and if the sound can be heard over the phone you can then try to re-install your sound card drivers.
You may have to disable the sound card altogether as well to stop Windows from automatically loading it's drivers - to do this just select "Disable" and then select "Uninstall" from the Device Manager.
