iTime Report post Posted 01/24/2014 01:20 AM Hello support team, I have just installed VG7 with HMP driver on Windows2008 R2 and while testing, I found out VG does not process an incoming call from the first module. If you see the log, "CheckTaskType" module is supposed to parse and generate a vbs file in "Temp" folder and usually records it to the log, "script will be ran from file: C:\Program Files (x86)\VoiceGuide\temp\vbs_xx_1.vbs", like the lines below: rv dbg rv_retrieve did not find [isBroadcasting] (.... script will be ran from file: C:\Program Files (x86)\VoiceGuide\temp\vbs_xx_1.vbs..... However, the log shows "runscr waiting. wait=1..." (without "Script will be ran...." part) then hangs up the call. Would it be a permission problem? I designated an application user to start VG service and that account is in Administrators group. Or something else? Thanks for your help in advance. Logs.zip Share this post Link to post
SupportTeam Report post Posted 01/24/2014 02:31 AM Trace shows that the VBScript in module CheckTaskType was started and ran and functions RvSet IsMoveAutoNotify and RvSet TTSSpeed were called from that VBScript. When VBScript finishes the 'next' module is not set, and no 'success' was returned, so VoiceGuide takes a fail path from that module (and if Fail path is not defined then VoiceGuide will hangup - which is what happens here) To determine what is happening in the script we would recommend adding some Admin_TracelogAdd() function calls into your script. You can see how the script progresses. Please see: http://www.voiceguide.com/vghelp/source/html/com_admin_tracelogadd.htm v7.4.2 uses a different way to execute the VBScript/JavaScript modules - this is why the vgEngine trace looks a bit different. You should see that VBScripts/JavaScripts run a lot faster in v7.4.2 then in previous VoiceGuide versions. Will check whether the actual "VoiceGuide\temp\vbs_xx_1.vbs" files are still created - they do not need to be created but maybe their creation can be enabled for debugging purposes. NB. v7.4.1 can still be downloaded from [old link removed] if required. 190753.988 4 3 1 runscr start - ClearScriptV8 190753.988 4 3 1 runscrunscr new VBScriptEngine call 190754.032 4 3 1 runscrunscr new engine created 190754.033 4 3 1 state [CheckTaskType] RunScript, wait=1 190754.045 4 3 1 rv replace start (strlen>500) 190754.056 4 rv dbg rv_retrieve did not find [UserID] ( 55 73 65 72 49 44) 190754.056 4 rv dbg rv_retrieve did not find [AutoNotifyCallID] ( 41 75 74 6f 4e 6f 74 69 66 79 43 61 6c 6c 49 44) 190754.057 4 rv dbg rv_retrieve did not find [AutoNotifyMoveNotificationCallID] ( 41 75 74 6f 4e 6f 74 69 66 79 4d 6f 76 65 4e 6f 74 69 66 69 63 61 74 69 6f 6e 43 61 6c 6c 49 44) 190754.057 4 rv dbg rv_retrieve did not find [IsHiring] ( 49 73 48 69 72 69 6e 67) 190754.057 4 rv dbg rv_retrieve did not find [IsBroadcasting] ( 49 73 42 72 6f 61 64 63 61 73 74 69 6e 67) 190754.057 4 3 1 runscr waiting. wait=1 190754.060 4 3 1 moh file not specified 190754.060 4 3 1 runscr .Execute call 190754.080 16 remoting link constructor activated: vgServices_CommandLink 190754.086 16 3 1 rem RvSet IsMoveAutoNotify, false 190754.088 16 3 1 rv add IsMoveAutoNotify|false 190754.092 16 3 1 rem RvSet TTSSpeed, 190754.092 16 3 1 rv add TTSSpeed| 190754.093 4 3 1 runscr .Execute returned. iRunWait=1 190754.093 4 3 1 runscr RunWait_1 script completed 190754.094 4 3 1 runscr RunWait_1 taking fail path as script completed and no next module set 190754.102 4 3 1 HangupCall (RunModule_Script_AfterScriptStarted_1) crn_in=0, L1=Connected, L2=Running_Normal, lPlayId=0, lRecId=0 Share this post Link to post
SupportTeam Report post Posted 01/24/2014 03:50 AM Looks like current v7.4.2 does not create the "VoiceGuide\temp\vbs_xx_1.vbs" files as it is unnecessary to create them. Future versions will have option to have these files created for debugging purposes. To enable this option you will need to edit VG.INI file, adding this entry to the [moduleRunScript] section: SaveToFile=1 Share this post Link to post
