masdaralhulool Report post Posted 02/05/2014 08:28 AM Hello, Please kindly assist me, because when i try to call the ivr, it always ringing. Then i try to restar the ivr, then it is okay again. but when the time passing by, suddenly when i call again its shows only ringing when i check the logs i see when the soundfile turn the ivr not pay it, then ringing. Please kindly help me in this problem Thanks and regards 0205_1218_vgEngine.txt 0205_ktTel.txt 0205_ktTts.txt Share this post Link to post
SupportTeam Report post Posted 02/05/2014 11:40 AM Traces show that you have not registered the VoiceGuide software. You need to register the VoiceGuide software to let it run continuously. If you have not registered VoiceGuide then VoiceGuide will stop answering calls after a while. To register the software you will need to purchase the license. The license purchase can be made here: https://secure.voiceguide.com/order_vg.htm Please let us know if you have any questions, Share this post Link to post
