kaangyib Report post Posted 02/10/2014 05:25 AM Hi Support team, I had designed the VG script to allow caller to use Fax on Demand option where they will press on the "Start" button on their fax machine to receive fax when they hear the fax tone. After they receive fax, I want to let the caller to get the next module playing "please press 8" to return to the main menu and continue using the IVR without the need of calling back to the system again. Right now, each time the caller finsihed receiving the fax, the system will cut off the line. I had enter "on {timeout} goto [success_Fax4]" in the fax sending module in the VG script where Success_Fax4 is the prompt for the caller to listen "please press 8 to return to the main menu" and it's not working. Please advise. Meanwhile, I realized that if the fax sending is more than 120 seconds, and the number of pages needed to be fax over is around 30 pages, once the timer hit 120 seconds, the remaining pages will turn out to be all blank printed out by the fax machine. What could be the issue? Thank you! Share this post Link to post
SupportTeam Report post Posted 02/10/2014 12:35 PM Please post the script that you are using along with the vgEngine trace capturing system startup and the call. We can then see how the call is handled on this system. Please also post the vgEngine and ktTel traces that capture the call during which the fax issue that you mention occurred. Share this post Link to post
kaangyib Report post Posted 02/11/2014 02:07 AM Hi Support team, Kindly find attached files. Archive.zip Share this post Link to post
SupportTeam Report post Posted 02/11/2014 02:37 AM You can use a path like this: on {TFX_FAXSEND_OK} goto [success_Fax4] or just: on {TFX_FAXSEND} goto [success_Fax4] but it looks like for some reason the call disconnects soon after the fax sending is completed. Most likely the remote fax machine is hanging up the call after the fax reception is completed. Trace shows that fax send was successful and the Disconnect afterwards seems to come from the other party. Can you please .ZIP and post the ktTel trace file for the same day. (to match up with posted vgEngine trace). We can then confirm whether it was the other party (the receiving fax machine) that hung up the call. 130156.877 6 2 1 state [FAX SEND DEMO1] Sending Fax C:\Fax\Sales\MY\0002016068.pdf 130156.877 6 2 1 strDialoutOptions= 130156.877 6 2 1 fax Pdf2Tif_Start begin C:\Fax\Sales\MY\0002016068.pdf=>C:\Fax\Sales\MY\0002016068.tif 130156.877 6 2 1 fax starting pdf->tif convert task 130156.877 6 fax pdf Pdf2Tif_ThreadContainer constr sFnameTiff_In=C:\Fax\Sales\MY\0002016068.pdf, sFnamePdf_In=C:\Fax\Sales\MY\0002016068.tif 130156.878 6 2 1 fax Pdf2Tif_Start end 130156.878 5 2 1 fax Pdf2Tif_ThreadContainer.Run begin 130156.878 6 2 1 SendFax_Start Pdf2Tif_StartIfConversionRequired started conversion 130156.878 5 2 1 fax pdf Process FileName=[C:\Program Files (x86)\VoiceGuide\gs\gswin32c.exe], Arguments=[-dSAFER -dBATCH -dNOPAUSE -sDEVICE=tiffg3 -g1728x2200 -r200 -sOutputFile="C:\Fax\Sales\MY\0002016068.tif" "C:\Fax\Sales\MY\0002016068.pdf"] 130157.146 5 2 1 q scr add evScriptEvent 0 FAX_PDF2TIF_CONVERT_COMPLETE 130157.146 6 2 1 q scr run evScriptEvent sCode=[FAX_PDF2TIF_CONVERT_COMPLETE] iActionID=0, crn=0[0|0|0|0|0][C:\Fax\Sales\MY\0002016068.tif|C:\Fax\Sales\MY\0002016068.pdf||||] 00:00:00 max:2|00:00:00.0010000 130157.146 6 2 1 scriptevent FAX_PDF2TIF_CONVERT_COMPLETE 0|0|0 C:\Fax\Sales\MY\0002016068.tif|C:\Fax\Sales\MY\0002016068.pdf| LineState=LS_PLAY_PLAYMSG 130157.146 6 2 1 LsPlayMsg EV_UNKNOWN_0,FAX_PDF2TIF_CONVERT_COMPLETE 130157.146 6 2 1 path {FAX_PDF2TIF_CONVERT_COMPLETE} not found 130157.146 6 2 1 LsPlayMsg ktTel_Fax_Tx_Start_Enqueue call [C:\Fax\Sales\MY\0002016068.tif] 130157.146 6 2 1 q tel add cmd_Fax_Tx_Start [0,0,0,0,0][C:\Fax\Sales\MY\0002016068.tif||||] 130157.147 6 2 1 t timer set 120 sec : EV_TIMEOUT_HANGUP 130157.147 7 2 1 q tel run cmd_Fax_Tx_Start 00:00:00 max:1|00:00:00.0150008 130226.628 18 2 1 ev Dialogic 164,TFX_PHASEB, crn=2800016, 0,0,0,status=[DFS_DIS][ ????????][DFS_DCS][] coding=[DFS_MR], speed=14400, state=8,, 130226.628 18 2 1 state Sending Fax: status=[DFS_DIS][ ????????][DFS_DCS][] coding=[DFS_MR], speed=14400, state=8 130226.628 18 2 1 ls set Connected (scriptstate=LS_FAX_TX) 130226.628 18 2 1 t timer clear (force=False) 130252.635 18 2 1 ev Dialogic 165,TFX_PHASED, crn=2800016, 0,0,0,status=0x600 coding=1, speed=14400, state=8,, 130252.635 18 2 1 q scr add evScriptEvent 165 TFX_PHASED 130252.635 6 2 1 q scr run evScriptEvent sCode=[TFX_PHASED] iActionID=0, crn=2800016[0|0|0|0|0][status=0x600 coding=1, speed=14400, state=8|||||] 00:00:00 max:2|00:00:00.0010000 130252.635 6 2 1 scriptevent TFX_PHASED 0|0|0 status=0x600 coding=1, speed=14400, state=8|| LineState=LS_FAX_TX 130252.635 6 2 1 LsFaxTx TFX_PHASED 0 status=0x600 coding=1, speed=14400, state=8 130310.091 18 2 1 ev Dialogic 161,TFX_FAXSEND, crn=2800016, 0,0,0,OK,, 130310.091 18 2 1 outgoing fax sending has either completed or errored out. 130310.091 18 2 1 path {TFX_FAXSEND_OK_} not found 130310.091 18 2 1 path {TFX_FAXSEND_OK} not found 130310.091 18 2 1 path {TFX_FAXSEND} not found 130310.091 18 2 1 q scr add evScriptEvent 161 TFX_FAXSEND 130310.091 6 2 1 q scr run evScriptEvent sCode=[TFX_FAXSEND] iActionID=0, crn=2800016[0|0|0|0|0][OK|||||] 00:00:00 max:2|00:00:00.0010000 130310.091 6 2 1 scriptevent TFX_FAXSEND 0|0|0 OK|| LineState=LS_FAX_TX 130310.091 6 2 1 LsFaxTx TFX_FAXSEND 0 OK 130310.091 6 2 1 rv add FAX SEND DEMO1_fax|OK 130310.091 6 2 1 path {TFX_FAXSEND} not found 130310.091 6 2 1 path {FAXTX} not found 130310.091 6 2 1 FindNextVgmTitleInPathList: next module title is=[Success_Fax4] 130310.092 6 2 1 t timer clear (force=False) 130310.092 6 2 1 RunModule start Play, [Success_Fax4], iModuleIdx=396, previous: vgm=373, vgs=1:1 130310.092 6 2 1 [Success_Fax4] VGMTYPE_PLAY run start 130310.092 6 2 1 CheckForAnyPlayActionsAndSetkeysIfNecessary no PlayActions, vgmidx=396, strPaths=on {8} goto [Menu_2_3] 130310.092 6 2 1 PrepareAndPlayWavAndTts start iModuleIdx=396, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs= 130310.092 6 2 1 PrepareAndPlayWavAndTTS sPlayFile=pr-006a.wav 130310.092 6 2 1 state [Success_Fax4] Playing wav (pr-006a.wav) 130310.092 6 2 1 FindSoundFile start [pr-006a.wav] 130310.092 6 2 1 t timer clear (force=False) 130310.092 6 2 1 q tel add cmd_PlayStart 870363 ,C:\Program Files (x86)\VoiceGuide\System\voice_Malay\pr-006a.wav [] 130310.092 6 2 1 play start ok, playId=870363 130310.092 7 2 1 q tel run cmd_PlayStart 00:00:00 max:1|00:00:00.0150008 130311.046 18 2 1 ev CallState GCEV_DISCONNECTED, crn=2800016, iEvent=2 ,16384,0,64, s1:, s2:, s3:]. build_date: 2013-05-27 20:38:30.13 130311.046 18 2 1 q scr add evCallState 2 GCEV_DISCONNECTED 130311.046 6 2 1 q scr run evCallState sCode=[GCEV_DISCONNECTED] iActionID=0, crn=2800016[16384|0|64|0|0][|||||] 00:00:00 max:2|00:00:00.0010000 130311.046 6 2 1 LineEvCallState crn=2800016 event=2|GCEV_DISCONNECTED iCallState=16384 calldirection=0 gcCallState=64 [||] 130311.046 6 2 1 LineEvCallState eLineStateThisEvent=Disconnected, ScriptState=LS_PLAY_PLAYMSG 130311.046 6 2 1 HangupCall, source=LINECALLSTATE_DISCONNECTED, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=870363, lRecId=0 Share this post Link to post
SupportTeam Report post Posted 02/11/2014 02:40 AM Also please update system to latest version of VoiceGuide software and the latest Dialogic drivers (both available from our WWW Downloads page) Share this post Link to post
kaangyib Report post Posted 02/11/2014 09:49 AM on {TFX_FAXSEND_OK} goto [success_Fax4] or just: on {TFX_FAXSEND} goto [success_Fax4] Hi Support team, I tried the same as mentioned in the quote. It still hangup. Kindly find attached zip kTel log file. Thanks! 0205_ktTel.txt.zip Share this post Link to post
SupportTeam Report post Posted 02/11/2014 09:54 AM ktTel trace confirms that remote fax machine has hung up the call after it has successfully received the sent fax.. 553 130310.091 3516 4 ev TFX_FAXSEND (Send fax complete) 554 130310.091 3516 2 fax Sent 2 pages at speed 14400, resln 196, width 1728 termination reason: OK 555 130310.091 3516 2 fax IottFaxFhandles_Close begin 556 130310.091 3516 2 fax dx_fileclose call idx=0, io_handle=4 557 130310.091 3516 2 fax IottFaxFhandles_Close end 558 130310.091 3516 2 r Dialogic TFX_FAXSEND 161 (0 0 0 OK ) ... 579 130311.046 3516 2 ev GCEV_DISCONNECTED crn=2800016 580 130311.046 3516 2 gc_ResultValue: event 0x826 received on ldev: 2 - Normal completion 581 130311.046 3516 2 gc_ResultValue: GC_ISDN_LIB 0x826 received on ldev: 2 - Normal clearing 582 130311.046 3516 2 Event_CallState GCEV_DISCONNECTED iLineCallState=16384, hCall=2800016|41943062 m_pktTelProxyClient=00261670 583 130311.046 3516 2 r CallState GCEV_DISCONNECTED Share this post Link to post
