Guest joneschik Report post Posted 02/19/2014 09:44 PM Is there a way to assign or change the value of the $RV_DeviceID? Share this post Link to post
SupportTeam Report post Posted 02/19/2014 10:07 PM There is no way to change this value. That $RV holds a value corresponding to the device used by the line/channel handing the call. Would you like to like to be able to change this value or are you just seeking to confirm that it cannot be changed? If you are trying to change this value then can you outline what needs to be achieved in your script? We may be able to suggest an alternative approach. Share this post Link to post
Guest joneschik Report post Posted 02/19/2014 11:01 PM We have a 4-port system. The device IDs on the ports are 3, 7, 10 and 13. We would like for the ports that come up with device number 10 and 13 to come up with only one-digit instead of two. Share this post Link to post
SupportTeam Report post Posted 02/19/2014 11:17 PM Suggest using: $RV_PORTNUMBERThis will return 1 to 4 depending on port/channel used by the call. For more information please see: http://www.voiceguide.com/vghelp/source/html/resultvariables.htm Share this post Link to post
Guest joneschik Report post Posted 02/20/2014 08:35 PM We are using the VGRUNRESULTS file and it adds the DEVICEID to the end of the file name. If we use the PORTNUMBER in the script it will not match the VGRUNRESULTS file name. Is there a way to get the VGRUNRESULTS to add the PORTNUMBER instead of the DEVICEID? Share this post Link to post
SupportTeam Report post Posted 02/20/2014 08:49 PM The VGRUNRESULTS files that can be used to return information to VoiceGuide need to be named using DEVICEID / LINEID. Alternative and faster way to return information to VoiceGuide scripts from external Programs or VBScripts/JavaScripts etc. is to use a WCF/COM interface. Please see: http://www.voiceguide.com/vghelp/source/html/com_run_resultreturn.htm Share this post Link to post
