keithwong Report post Posted 02/06/2004 06:49 AM Hi, I'm using 5.1.7 with win2000 server. Pls help. The outdial_dialed file show the pager was dialled. However, the call get log to OutDial_Uncontactable_NoAnswer file after all the retries. My pager didnt beep. The voiceguide show dialing: .... but didnt see the message sent. A timeout occurs. rgds, keith 143602.26 0 sys cleanup Start 143602.27 0 sys cleanup End 143701.55 4 linedevstate 2048 0 0 143701.55 4 callstate OFFERING 66133 0 4 143701.59 4 Answer the call at 2/6/2004 2:37:01 PM 143701.60 4 lineAnswer(66133) => 66116 143701.60 4 callinfo CALLEDID 143701.60 4 callinfo ORIGIN 143701.60 4 ring 0 143702.13 4 callstate CONNECTED 66133,1,0 143702.13 4 WorkingModeTAPI@Connected= 143702.14 4 WorkingModeScript@Connected= 143702.17 4 Inband detection not enabled 143702.18 4 StartLoadedVgs at 2/6/2004 2:37:02 PM 143702.20 4 tapi Reply (LineEvReply) ok 66116 0 143702.20 4 [Greeting] Playing 143702.21 4 [Greeting] Playing (Greet0Announcement.wav) 143702.25 4 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\8111\Greet0Announcement.wav] 143702.25 4 RunModule PLAY end 143705.08 4 wb(19022300) 143705.13 4 Play End line[4] (id=190223) 143705.14 4 LsPlayMsg EV_PLAY_FINISHED 143705.15 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 143705.16 4 [start1290] Playing 143705.16 4 [start1290] Playing (Start1290.wav) 143705.21 4 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\8111\Start1290.wav] 143705.22 4 RunModule PLAY end 143708.26 4 dtmf 2 (66133,50,2) 143708.27 4 LsPlayMsg 2 143708.32 4 PlaySoundStop ok 143708.34 4 [2_Support] Playing 143708.34 4 [2_Support] Playing (NameDeptContactReq.wav) 143708.39 4 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\8111\NameDeptContactReq.wav] 143708.39 4 RunModule PLAY end 143715.57 4 dtmf 1 (66133,49,2) 143715.58 4 LsPlayMsg 1 143715.64 4 PlaySoundStop ok 143715.64 4 [Record SupportCall] Recording 143715.72 4 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 143715.92 4 wb(20370200) 143715.98 4 Play End line[4] (id=203702) 143715.99 4 LsRecPlayBeep EV_PLAY_FINISHED 143716.05 4 RecSoundStart file[D:\Support\0206143715_4_.wav] ok 143716.06 4 RecFile[D:\Support\0206143715_4_.wav] 143718.92 4 dtmf 0 (66133,48,2) 143718.93 4 LsRecRecording 0 143718.99 4 RecSoundStopTruncBytes ok 143719.00 4 rec length RV: Record SupportCall_RecLen100ms = 28 143719.01 4 [Page 8111] Send Pager Message 143719.01 0 dial DialListDB_AddCall '9,95918603', 402061437, 1, 2359, MoTuWeThFrSaSu, *8111##2**, DIAL_PAGER_NUMERIC, DIAL_PAGER_NUMERIC, , 60, 4, 2, ESCALATION: 143719.09 4 dial DialListDB_AddCall insert ok 143719.10 4 [req saved gdbye] Playing 143719.10 4 [req saved gdbye] Playing (ReqSavedGdbye.wav) 143719.13 4 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\8111\ReqSavedGdbye.wav] 143719.14 4 RunModule PLAY end 143719.94 0 dial callque update id=148 next call time 0402061439 143719.95 0 dial callque DB update returned 143719.96 5 dial found entry: tel[9,95918603] ann[*8111##2**] vgs[DIAL_PAGER_NUMERIC] am[DIAL_PAGER_NUMERIC] 143719.97 5 Calling MakeCallEx(9,95918603) 143719.98 5 Dialing: 9,95918603 143719.98 5 MakeCall => 66099 143719.99 5 TapiCbTrigSet 66099 7002 143720.77 5 tapi Reply (LineEvReply) ok 66099 0 143720.77 5 TapiCbTrigClear 143720.77 5 linedevstate 2048 0 0 143720.79 5 callstate DIALTONE 66065 0 0 143720.79 5 callstate DIALING 66065 0 0 143720.79 5 callstate PROCEEDING 66065 0 0 143720.80 5 callinfo CALLEDID 143720.81 5 callinfo REASON 143720.82 5 Lev_CallerID [0000,] 143720.84 5 callinfo ORIGIN 143726.74 4 Play End line[4] (id=207127) 143726.75 4 LsPlayMsg EV_PLAY_FINISHED 143726.76 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 143726.77 4 Hanging up call... [Hangup Module] 143726.78 4 RecSoundStop ok 143726.78 4 PlaySoundStop ok 143726.79 4 fnHangupCall end 143726.83 4 linedevstate 2048 0 0 143726.84 4 callstate IDLE 66133 0 0 143726.84 4 WorkingMode@Idle= 143726.90 4 tapi Reply (LineEvReply) ok 66048 0 143727.84 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 143727.86 4 ReinitTelephony due to IDLE start 143727.86 4 tapic lineDeallocateCall(MainCall:66133) 0 143728.02 4 lineOpen(4) => 0 143728.02 4 Waiting for a call... 143728.04 4 lineOpen(4)LineHandle=66047 143820.57 5 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE 143820.57 0 dial callque update id=148 next call time 0402061440 143820.57 0 dial callque DB update returned 143820.57 5 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE] 143820.57 5 RecSoundStop ok 143820.58 5 PlaySoundStop ok 143820.58 5 Waiting for a call... 143820.58 5 fnHangupCall end 143820.62 5 linedevstate 2048 0 0 143820.62 5 callstate IDLE 66065 0 0 143820.62 5 WorkingMode@Idle= 143820.62 5 LineState(iLineId).iVgsIdx = 0 143820.62 5 tapi Reply (LineEvReply) ok 66013 0 143821.59 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 143821.59 5 ReinitTelephony due to IDLE start 143821.59 5 tapic lineDeallocateCall(MainCall:66065) 0 143821.76 5 lineOpen(5) => 0 143821.76 5 Waiting for a call... 143821.76 5 lineOpen(5)LineHandle=65996 144000.98 0 dial callque update id=148 next call time 0402061442 144000.98 0 dial callque DB update returned 144000.99 4 dial found entry: tel[9,95918603] ann[*8111##2**] vgs[DIAL_PAGER_NUMERIC] am[DIAL_PAGER_NUMERIC] 144000.99 4 Calling MakeCallEx(9,95918603) 144000.99 4 Dialing: 9,95918603 144000.99 4 MakeCall => 65962 144000.99 4 TapiCbTrigSet 65962 7002 144001.75 4 tapi Reply (LineEvReply) ok 65962 0 144001.75 4 TapiCbTrigClear 144001.75 4 linedevstate 2048 0 0 144001.75 4 callstate DIALTONE 65928 0 0 144001.75 4 callstate DIALING 65928 0 0 144001.75 4 callstate PROCEEDING 65928 0 0 144001.75 4 callinfo CALLEDID 144001.75 4 callinfo REASON 144001.75 4 Lev_CallerID [0000,] 144001.75 4 callinfo ORIGIN 144101.08 4 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE 144101.08 0 dial callque update id=148 next call time 0402061443 144101.08 0 dial callque DB update returned 144101.08 4 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE] 144101.08 4 RecSoundStop ok 144101.08 4 PlaySoundStop ok 144101.09 4 Waiting for a call... 144101.09 4 fnHangupCall end 144101.13 4 linedevstate 2048 0 0 144101.13 4 callstate IDLE 65928 0 0 144101.13 4 WorkingMode@Idle= 144101.13 4 LineState(iLineId).iVgsIdx = 0 144101.13 4 tapi Reply (LineEvReply) ok 65911 0 144102.09 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 144102.09 4 ReinitTelephony due to IDLE start 144102.10 4 tapic lineDeallocateCall(MainCall:65928) 0 144102.25 4 lineOpen(4) => 0 144102.26 4 Waiting for a call... 144102.26 4 lineOpen(4)LineHandle=65894 144300.82 0 dial callque update id=148 next call time 0402061445 144300.83 0 dial callque DB update returned 144300.83 4 dial found entry: tel[9,95918603] ann[*8111##2**] vgs[DIAL_PAGER_NUMERIC] am[DIAL_PAGER_NUMERIC] 144300.83 4 Calling MakeCallEx(9,95918603) 144300.83 4 Dialing: 9,95918603 144300.83 4 MakeCall => 65860 144300.83 4 TapiCbTrigSet 65860 7002 144301.59 4 tapi Reply (LineEvReply) ok 65860 0 144301.59 4 TapiCbTrigClear 144301.59 4 linedevstate 2048 0 0 144301.59 4 callstate DIALTONE 65826 0 0 144301.59 4 callstate DIALING 65826 0 0 144301.59 4 callstate PROCEEDING 65826 0 0 144301.59 4 callinfo CALLEDID 144301.59 4 callinfo REASON 144301.59 4 Lev_CallerID [0000,] 144301.59 4 callinfo ORIGIN 144400.94 4 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE 144400.94 0 dial callque update id=148 next call time 0402061446 144400.96 0 dial callque DB update returned 144400.97 4 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE] 144400.97 4 RecSoundStop ok 144400.98 4 PlaySoundStop ok 144400.99 4 Waiting for a call... 144400.00 4 fnHangupCall end 144401.03 4 linedevstate 2048 0 0 144401.04 4 callstate IDLE 65826 0 0 144401.05 4 WorkingMode@Idle= 144401.06 4 LineState(iLineId).iVgsIdx = 0 144401.07 4 tapi Reply (LineEvReply) ok 65809 0 144402.01 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 144402.02 4 ReinitTelephony due to IDLE start 144402.03 4 tapic lineDeallocateCall(MainCall:65826) 0 144402.19 4 lineOpen(4) => 0 144402.20 4 Waiting for a call... 144402.21 4 lineOpen(4)LineHandle=65792 144600.74 0 dial callque update id=148 next call time 0402061448 144600.74 0 dial callque DB update returned 144600.74 4 dial found entry: tel[9,95918603] ann[*8111##2**] vgs[DIAL_PAGER_NUMERIC] am[DIAL_PAGER_NUMERIC] 144600.74 4 Calling MakeCallEx(9,95918603) 144600.74 4 Dialing: 9,95918603 144600.74 4 MakeCall => 65774 144600.74 4 TapiCbTrigSet 65774 7002 144601.50 4 tapi Reply (LineEvReply) ok 65774 0 144601.50 4 TapiCbTrigClear 144601.50 4 linedevstate 2048 0 0 144601.50 4 callstate DIALTONE 65740 0 0 144601.50 4 callstate DIALING 65740 0 0 144601.50 4 callstate PROCEEDING 65740 0 0 144601.50 4 callinfo CALLEDID 144601.50 4 callinfo REASON 144601.51 4 Lev_CallerID [0000,] 144601.51 4 callinfo ORIGIN 144700.00 4 LsWaitAfterDialingOut EV_TIMEOUT_MAKECALL_NORESPONSE 144700.00 0 dial callque update id=148 next call time 0402061449 144700.00 0 dial callque DB update returned 144701.01 4 Hanging up call... [EV_TIMEOUT_MAKECALL_NORESPONSE] 144701.01 4 RecSoundStop ok 144701.01 4 PlaySoundStop ok 144701.01 4 Waiting for a call... 144701.01 4 fnHangupCall end 144701.05 4 linedevstate 2048 0 0 144701.05 4 callstate IDLE 65740 0 0 144701.05 4 WorkingMode@Idle= 144701.05 4 LineState(iLineId).iVgsIdx = 0 144701.05 4 tapi Reply (LineEvReply) ok 65723 0 144702.01 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 144702.01 4 ReinitTelephony due to IDLE start 144702.01 4 tapic lineDeallocateCall(MainCall:65740) 0 144702.17 4 lineOpen(4) => 0 144702.17 4 Waiting for a call... 144702.17 4 lineOpen(4)LineHandle=65706 144900.49 0 dial callque update id=148 next call time 0402061451 144900.50 0 dial callque DB update returned 144900.50 4 dial found entry: tel[9,95918603] ann[*8111##2**] vgs[DIAL_PAGER_NUMERIC] am[DIAL_PAGER_NUMERIC] 144900.50 4 Calling MakeCallEx(9,95918603) 144900.50 4 Dialing: 9,95918603 144900.50 4 MakeCall => 65672 144900.50 4 TapiCbTrigSet 65672 7002 144901.25 4 tapi Reply (LineEvReply) ok 65672 0 144901.25 4 TapiCbTrigClear 144901.25 4 linedevstate 2048 0 0 144901.25 4 callstate DIALTONE 65638 0 0 144901.26 4 callstate DIALING 65638 0 0 144901.26 4 callstate PROCEEDING 65638 0 0 144901.26 4 callinfo CALLEDID 144901.26 4 callinfo REASON 144901.26 4 Lev_CallerID [0000,] 144901.26 4 callinfo ORIGIN Share this post Link to post
SupportTeam Report post Posted 02/07/2004 12:46 AM Looks like the modem that you are using does not work very well when dialing out in Voice mode... modem does not issue a "Connected" message after dialing and that is why you are seeing the EV_TIMEOUT_MAKECALL_NORESPONSE timeout message after one minute. I'd suggest trying another modem... For reference the trace of the outbound call should look someting like this: 114259.77 9 dial found entry: tel[19] ann[8111##2**] vgs[DIAL_PAGER_NUMERIC] am[DIAL_PAGER_NUMERIC] 114259.80 9 Dialing: 19 114259.81 9 MakeCall => 66458 114259.81 9 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE 114259.81 9 TapiCbTrigSet 66458 7002 114300.39 9 tapi Reply (LineEvReply) ok 66458 0 114300.39 9 TapiCbTrigClear 114300.39 9 linedevstate 2048 0 0 114300.39 9 callstate DIALTONE 66424 0 0 114300.39 9 callstate DIALING 66424 0 0 114300.39 9 callstate PROCEEDING 66424 0 0 114300.39 9 callinfo CALLEDID 114300.41 9 callinfo REASON 114300.41 9 Lev_CallerID [0000,] 114300.41 9 callinfo ORIGIN 114313.63 9 callstate CONNECTED 66424,1,0 114313.64 9 WorkingModeTAPI@Connected= 114313.64 9 WorkingModeScript@Connected= 114313.66 9 Sending Numeric Pager Message 114313.66 9 TimeoutSet 2 EV_TIMEOUT_WAITBEFORESENDINGPAGERMESSAGE 114313.67 0 dial callque delete id=4 114315.78 9 Timer fired EV_TIMEOUT_WAITBEFORESENDINGPAGERMESSAGE 114315.78 9 ScriptEventCode 9010 iLineState=1140 114315.78 9 LsOutboundCall_NumericPager EV_TIMEOUT_WAITBEFORESENDINGPAGERMESSAGE 114315.78 9 Playing numeric pager message:8111##2** 114315.78 9 TimeoutSet 30 EV_TIMEOUT_HANGUP 114315.80 9 tapic lineGenerateDigits(66424,8111##2**,100) => 0 114317.66 9 generate LINEGENERATETERM_DONE 114317.66 9 TimeoutSet 1 EV_TAPI_GENERATE 114318.75 9 Timer fired EV_TAPI_GENERATE 114318.75 9 ScriptEventCode 9602 iLineState=1140 114318.75 9 LsOutboundCall_NumericPager EV_TAPI_GENERATE 114318.75 9 TimeoutSet 5 EV_TIMEOUT_HANGUP 114324.22 9 Timer fired EV_TIMEOUT_HANGUP 114324.22 9 ScriptEventCode 9001 iLineState=1140 114324.22 9 LsOutboundCall_NumericPager EV_TIMEOUT_HANGUP 114324.22 9 Hanging up call... [pager] Share this post Link to post
keithwong Report post Posted 02/09/2004 01:06 AM This is no modem. I'm using a D/4 PCI recommended hardware. Share this post Link to post
SupportTeam Report post Posted 02/09/2004 02:04 AM When you call the pager telephone number (95918603) is the call answered with a prompt asking caller to enter the number or is it just silence? From the trace it appears as if the call was not answered at all - even if the call is answered with just silence then the Dialogic card will report connected after about 5-10 seconds. The demo trace shown in previous post was made with a D/4PCI card as well. Share this post Link to post
keithwong Report post Posted 02/13/2004 01:06 AM When the number was dialed, there will be a fast beeping sound for about 3-4 sec waiting for our input. This is something from the paging company. I connect a phone parallel to the line that was dialing out. When it start to dial, I quickly pick up my handset. I heard the number being dialed but the message numbers was not. Share this post Link to post
SupportTeam Report post Posted 02/13/2004 03:50 AM Looks like for some reason the Dialogic card cannot tell when the call has been answered if those beeps are played... we'll try looking into this but in the meantime the workaround would be to just specify the message to be delivered as part of the phone number itself and just use a few commas to delay the playing of the message after the phone number is dialed to make sure that call has been answered by the paging agency by the time the message starts playing. ie: for the phone number just specify: 9,95918603,,,*8111##2** add or delete commas as needed... Share this post Link to post
