hugh Report post Posted 02/07/2004 03:30 PM Two questions: 1. Last year when enquiring about D/4PCI setup issues you mentioned a Dialogic version which would not use TAPI, when is this expected? 2. Is it possible to records an entire call from answer to hangup while other modules are being used. The application here is for an outbound system which will prompt for various input keys to be pushed, but there is a requirement to record anything heard on the line. Share this post Link to post
SupportTeam Report post Posted 02/07/2004 11:52 PM Quote Dialogic version which would not use TAPI, when is this expected? There is no release date for this version yet. Quote Is it possible to records an entire call from answer to hangup while other modules are being used. No. You should look at using an external call recorder. Share this post Link to post
