Callerid From Within Script
Hello,
I know you can set the callerid on an outbound dialler caller like this:
<CallOptions>
<CallerID>111111</CallerID>
</CallOptions>
And in the config files for lines, but can you please tell us how we would set the callerid from within a script?
To set Caller ID on outgoing leg of a tromboned transfer (Dial and Conference transfer):
From: http://www.voiceguide.com/vghelp/source/html/modxfer.htm
The Options field can be used to specify the outgoing CallerID used for the call by using the XML syntax. eg: specifying <CallerId>5551234</CallerId> would result in CallerId to be set to 5551234 on outgoing calls.
