invoso.com Report post Posted 05/05/2014 06:08 AM We have problems with sending emails from vg. log: 074353.358 7 7 3 RunModule start Send Email, [send Email], iModuleIdx=618, previous: vgm=618, vgs=11:11074353.359 7 7 3 state [send Email] Send Email074353.358 77 7 3 db odbc query completed.074353.359 7 7 3 rv replace start [$RV[id_proj_pg_email]]074353.359 7 7 3 rv replace end [maciej@invoso.com]074353.359 7 7 3 rv replace start------------------------------Dnia: $RV_YY-$RV_MM-$RV_DD o godzinie: $RV_HH:$RV_NN abonent numeru: $RV_CIDNUMBER pozostawil nagranie w załaczniku.------------------------------074353.359 7 7 3 rv replace end [Dnia: 14-05-05 o godzinie: 07:43 abonent numeru: 502131638 pozostawil nagranie w załaczniku.]074353.359 7 7 3 rv replace start [c:\abc.mp3]074353.359 7 7 3 rv replace end [c:\abc.mp3]074353.360 7 7 3 rv add Send Email|maciej@invoso.com074353.360 7 7 3 rv add Send Email_Subject|Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.074353.360 7 7 3 rv add Send Email_Message|Dnia: 14-05-05 o godzinie: 07:43 abonent numeru: 502131638 pozostawil nagranie w załaczniku.074353.360 7 7 3 rv add Send Email_Attachment|c:\abc.mp3074353.361 7 7 3 rv add Send Email_Cc|074353.361 7 7 3 rv add Send Email_Bcc|infolinia@invoso.com074353.361 7 7 3 email to: maciej@invoso.com074353.361 7 AddEmailToSend from:infolinia@agenta.pl|infolinia@agenta.pl, to:maciej@invoso.com, cc:, bcc:infolinia@invoso.com, reply:infolinia@agenta.pl, subj:Wiadomosc poczty glosowej z infolinii TELESTRADA S.A., att:c:\callrecord\manager11\ID20140505074320183.mp3, usertoken:(<to>maciej@invoso.com</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>c2efcfac-a0e9-4a3d-a9c9-ee4520b127dd</guid>) smtp:ssl:smtp.agenta.pl|587 timeout:300sec, sParamsXml:074353.362 7 SmtpClient created ok074353.362 7 setting EnableSsl as port = 587074353.362 7 .Host=smtp.agenta.pl .Port=587 .EnableSsl=True sCredentialUserName=[user]074353.362 7 SmtpClient clientEs configured ok074353.362 7 email send start <to>maciej@invoso.com</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>c2efcfac-a0e9-4a3d-a9c9-ee4520b127dd</guid>, timeout=300sec074353.385 7 email SendAsync returned074353.386 7 7 3 email queued for sending.074353.386 7 7 3 rv add Send Email_SendResult|ok074353.386 7 7 3 FindNextVgmTitleInPathList: next module title is=[Hangup the Call 1]074353.386 7 7 3 t timer clear (force=False)074353.386 7 7 3 RunModule start Hangup the Call, [Hangup the Call 1], iModuleIdx=621, previous: vgm=618, vgs=11:11074353.386 7 7 3 HangupCall (Hangup Module) crn_in=0, L1=Disconnected, L2=Running_AfterHangup, lPlayId=0, lRecId=0074353.386 7 7 3 ccrn_connected=0, crn_NewIncomingCall=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=2cc01cb074353.386 7 7 3 rv add Hangup Source|Hangup Module074353.387 7 7 3 rv add DropCall_Source|Hangup the Call 1074353.387 7 7 3 state Hanging up... [Hangup Module]074353.387 7 7 3 WriteToLogFiles_CurrScriptOnly begin074353.387 7 7 3 WriteToLogFiles_DoWrite begin : strLogFnameLessSuffix=C:\Program Files (x86)\VoiceGuide\Scripts\manager\manager_termination074353.387 7 7 3 WriteToLogFiles_DoWrite : log subdirectory exists, strLogFnameLessSuffix=C:\Program Files (x86)\VoiceGuide\Scripts\manager\log\manager_termination074353.798 77 email send error. <to>maciej@invoso.com</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>c2efcfac-a0e9-4a3d-a9c9-ee4520b127dd</guid> System.Net.Mail.SmtpException: Failure sending mail. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. at System.Net.Mail.SmtpConnection.ConnectAndHandshakeAsyncResult.End(IAsyncResult result) at System.Net.Mail.SmtpClient.ConnectCallback(IAsyncResult result) --- End of inner exception stack trace ---074354.301 7 7 3 WriteToLogFiles_DoWrite completed074354.301 7 7 3 RvSaveToLogFiles_CurrAndStack iScriptCallStack_LastUsed_Idx=0074354.301 7 7 3 L2_set Idle_WaitingForNextCall (called from HangupCall)074354.301 7 7 3 t timer set 3 sec : EV_TIMEOUT_AFTERIDLE_ALLOWOUT074354.301 7 7 3 GoOnHoook_IssueDropCall start (crn_in=2cc01cb, crn_connected=0, crn_makecall=0, crn_NewCallArriving=0, crn_InProcessOfReleasing=2cc01cb, L1=Disconnected)074354.301 7 7 3 t timer set 20 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall074354.302 7 7 3 set crn_InProcessOfReleasing=2cc01cb074354.302 7 7 3 set crn_connected=0 (called from GoOnHoook_IssueDropCall)074354.302 7 7 3 q_tel + cmd_DropCall 2cc01cb [0,0,0,0,0][||||]074354.302 7 7 3 GoOnHoook_IssueDropCall end074354.302 8 7 3 q_tel run cmd_DropCall 2cc01cb 00:00:00 max:5|00:00:00.2790160 VG not using alternate email send method. Each time after unsuccessful email send process VG terminating module. We use configuration: SMTP Server: ssl:smtp.agenta.pl port:587 This same configuration settings working on thunderbird but not in VG. Share this post Link to post
SupportTeam Report post Posted 05/05/2014 06:51 AM The error returned by .NET's email sending routines is: The remote certificate is invalid according to the validation procedure. This apparently can be caused by the email server's SSL certificate not being imported in properly, or SSL certificate was actually created for a differnet URL, or there is a date mismatch on the machines, etc. Some trobleshooting instructions from Microsoft for this error can be found here: http://blogs.msdn.com/b/jpsanders/archive/2009/09/16/troubleshooting-asp-net-the-remote-certificate-is-invalid-according-to-the-validation-procedure.aspx?Redirected=true Share this post Link to post
invoso.com Report post Posted 05/07/2014 07:17 AM other problem: 082912.225 7 SmtpClient created ok082912.225 7 setting EnableSsl as port = 587082912.225 7 .Host=ta.hb.pl .Port=587 .EnableSsl=True sCredentialUserName=[poczta.glosowa.infolinii@telestrada.hb.pl]082912.225 7 SmtpClient clientEs configured ok082912.225 7 email send start <to>maciej@____.pl</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>6b5f1629-5ae1-4567-82fb-acbf46deb640</guid>, timeout=300sec082916.231 7 ERROR v7.4.5207.24383 (2014-04-04 13:32:46.19) AddEmailToSend SendAsync: The SMTP host was not found.082916.231 7 31 11 email not queued for sending.082916.231 7 31 11 rv add Send Email_SendResult|The SMTP host was not found.082916.232 7 31 11 FindNextVgmTitleInPathList: next module title is=[Hangup the Call 1]082916.232 7 31 11 t timer clear (force=False)082916.232 7 31 11 RunModule start Hangup the Call, [Hangup the Call 1], iModuleIdx=566, previous: vgm=563, vgs=11:11082916.232 7 31 11 HangupCall (Hangup Module) crn_in=0, L1=Disconnected, L2=Running_AfterHangup, lPlayId=0, lRecId=0082916.232 7 31 11 ccrn_connected=0, crn_NewIncomingCall=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=2b00327082916.232 7 31 11 rv add Hangup Source|Hangup Module082916.232 7 31 11 rv add DropCall_Source|Hangup the Call 1 But Host=poczta.hb.pl not ta.hb.pl as show VG. Why VG cutting part of HOST name? Share this post Link to post
SupportTeam Report post Posted 05/07/2014 07:26 AM Can you please try using this as the host name: ssl:poczta.hb.pl Share this post Link to post
