meir Report post Posted 05/24/2014 05:56 PM Hello, We Changed the OS to Windows 2008 Server 32 bit (SP2) After that , Vg fails when reaching " CreateObject("WScript.Shell") " line in our VBScripts According the NOTE event in vgEngine Log file , We added this entry to [moduleRunScript] section of VG.INI : Engine=WSH ,but problem wasn't fix. Machine info: Windows 2008 Server 32-bit (SP2) .NET 4.0 VoiceGuide v7.4.4 D4PCIUFEQEU Dialogic Card File is attached. Thank you. Error.zip Share this post Link to post
SupportTeam Report post Posted 05/24/2014 10:46 PM The script in VoiceGuide's "Run VBS" module is: Option Explicit Dim vg Set vg = CreateObject("vgServices.CommandLink") vg.RvSet $RV_LINEID, "debug_line", "5" Dim fso , objShell vg.RvSet $RV_LINEID, "debug_line", "7" Set fso = CreateObject("scripting.filesystemobject") vg.RvSet $RV_LINEID, "debug_line", "9" Set objShell = CreateObject("WScript.Shell") vg.RvSet $RV_LINEID, "debug_line", "11" Set fso = nothing Set objShell = nothing vg.Run_ResultReturn $RV_LINEID, "success" Set vg = Nothing Why do you need to create the "WScript.Shell" object? Can you post the rest of the script that shows how the WScript.Shell object is then used ? VoiceGuide v7.4.4 uses a different method of running VBScript - which is much faster - but it no longer uses the WScript/CScript to run the scripts in the "Run VBS" modules. To have system use the old Wscript/CScript way of running the VBScript snippets please set this in VG.INI file, in section [moduleRunScript] Engine=wscript Share this post Link to post
meir Report post Posted 05/25/2014 10:55 PM Regarding VBS compatibility: What vbscript Commands / Functions / Objects , can be used in the new VoiceGuide v7.4.4 I would like to get more details, Thanks. We use the "run" Method in "WScript.Shell" object. In order to interact with other commands on system and also simplifying various tasks in the vbs code, Here is an example: Sorting alphabetically a file list and finding a file that is located before other file option Explicit Const ForReading = 1 Dim fso , vg , WshShell , strDirPath ,strCurrentFileName , strCommandOutput , strCommand , strPreviousFileName set vg = CreateObject("vgServices.CommandLink") Set fso = WScript.CreateObject("Scripting.Filesystemobject") Set WshShell = WScript.CreateObject("Wscript.Shell") strDirPath = "d:\data\" strCurrentFileName = "$RV[current_file_name]" strCommandOutput = "d:\temp\command_output.txt" strCommand = "%comspec% /c Dir /oN /B " & chr(34) & strDirPath & chr(34) & " | grep -B1 " & strCurrentFileName & " | grep -v " & strCurrentFileName & " > " & chr(34) & strCommandOutput & chr(34) WshShell.Run strCommand,0,True strPreviousFileName = fso.OpenTextFile (strCommandOutput ,ForReading).ReadLine vg.RvSet $RV_LINEID, "previous_file_name", strPreviousFileName ... Share this post Link to post
SupportTeam Report post Posted 05/26/2014 12:00 AM Just the WScript object is not available. Please try using: set objShell = CreateObject("shell.application") objShell.ShellExecute strCommand, "", "", "runas", 0 Please see: http://msdn.microsoft.com/en-us/library/windows/desktop/gg537745%28v=vs.85%29.aspx?cs-save-lang=1&cs-lang=vb#code-snippet-1 http://ss64.com/vb/shellexecute.html you could even use shell.application object to start a cscript/wscript intepretor, like this: set objShell = CreateObject("shell.application") objShell.ShellExecute "cscript", "E:\demo\vbscript.vbs", "", "runas", 0 Setting in VG.INI: [moduleRunScript] Engine=WScript Note: WScript not WSH should switch system back to using the old WScript way of running the VBS scripts. If you have problems when Engine=WScript is set then please post trace capturing that call Share this post Link to post
meir Report post Posted 05/28/2014 05:39 AM After switching back to the old WScript way of running the VBS scripts, the scripts are executed by vg. But it takes a lot time to process each script, comparing the time it took in vg v7.3 (on Win XP) Regarding Using the new way of running the VBS scripts: Using "Shell.application" Object for running command, How can I wait until the process has finished? Share this post Link to post
SupportTeam Report post Posted 05/28/2014 06:03 AM Setting Engine=WScript should result in the wscript.exe interpreter being used - as in older versions. If you are seeing that the script runs slower then have you tried to use some logging to determine where the script slows down? With Shell.application's ShellExecute command, perhaps you may need to use a loop to check for some file based flag that gets set at end of process called by ShellExecute ? Don't know enough about VBScript to know if that is the best approach or not. Share this post Link to post
